My samba used to work without problem i think the last time it works when it was on 0.64.3 i dont use much samba other than to backup my config. i upgraded my hassio couple of times now it wont start at all clicking start doesn’t work either this is my system logs but i am not sure how to resolve.
18-04-05 03:35:30 INFO (MainThread) [hassio.addons.addon] Create Home-Assistant addon data folder /data/addons/data/core_samba
18-04-05 03:35:30 INFO (SyncWorker_7) [hassio.docker.interface] Pull image homeassistant/armhf-addon-samba tag 3.0.
18-04-05 03:35:59 INFO (SyncWorker_7) [hassio.docker.interface] Tag image homeassistant/armhf-addon-samba with version 3.0 as latest
18-04-05 03:35:59 WARNING (SyncWorker_15) [hassio.docker.interface] Can't grap logs from homeassistant/armhf-addon-samba: 500 Server Error: Internal Server Error ("can not get logs from container which is dead or marked for removal")
18-04-05 03:36:45 INFO (SyncWorker_18) [hassio.docker.interface] Clean homeassistant/armhf-addon-samba docker application
18-04-05 03:36:47 ERROR (SyncWorker_18) [hassio.docker] Can't create container from addon_core_samba: 409 Client Error: Conflict ("Conflict. The container name "/addon_core_samba" is already in use by container "06b1f58f5a4b5f920e76e44c89a029df5af68e1b63bcb9d35f72b3da7188076f". You have to remove (or rename) that container to be able to reuse that name.")
Thanks.
