Log
load_lmhosts_file: Can't open lmhosts file /etc/samba/lmhosts. Error was No such file or directory
daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
smbd version 4.10.8 started.
Copyright Andrew Tridgell and the Samba Team 1992-2019
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Processing section "[config]"
Processing section "[addons]"
Processing section "[ssl]"
Processing section "[share]"
Processing section "[backup]"
added interface docker0 ip=172.17.0.1 bcast=172.17.255.255 netmask=255.255.0.0
added interface hassio ip=172.30.32.1 bcast=172.30.33.255 netmask=255.255.254.0
added interface enp6s0 ip=192.168.31.45 bcast=192.168.31.255 netmask=255.255.255.0
INFO: Profiling support unavailable in this build.
No builtin backend found, trying to load plugin
tdb(/var/lib/samba/registry.tdb): tdb_open_ex: could not open file /var/lib/samba/registry.tdb: No such file or directory
daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
waiting for connections
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 172.17.0.1
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 172.30.32.1
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 192.168.31.45
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.17.0.1
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.30.32.1
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 192.168.31.45
run_elections: >>> Won election for workgroup WORKGROUP on subnet 172.17.0.1 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 172.17.0.1
run_elections: >>> Won election for workgroup WORKGROUP on subnet 172.30.32.1 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 172.30.32.1
run_elections: >>> Won election for workgroup WORKGROUP on subnet 192.168.31.45 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 192.168.31.45
Samba name server SERVER is now a local master browser for workgroup WORKGROUP on subnet 172.17.0.1
Samba name server SERVER is now a local master browser for workgroup WORKGROUP on subnet 172.30.32.1
Samba name server SERVER is now a local master browser for workgroup WORKGROUP on subnet 192.168.31.45
Denied connection from fe80::7d6e:2183:d0aa:d0a9 (fe80::7d6e:2183:d0aa:d0a9)
Connection denied from ipv6:fe80::7d6e:2183:d0aa:d0a9:50671 to ipv6:fe80::ea11:32ff:fe01:8ab2:445
check_ntlm_password: Authentication for user [[[email protected]](mailto:[email protected])] -> [[[email protected]](mailto:[email protected])] FAILED with error NT_STATUS_NO_SUCH_USER, authoritative=1
Auth: [SMB2,(null)] user [[MicrosoftAccount]\[[email protected]](mailto:MicrosoftAccount]\[[email protected])] at [Fri, 20 Mar 2020 15:07:23.116298 IST] with [NTLMv2] status [NT_STATUS_NO_SUCH_USER] workstation [DESKTOP-SHFC62V] remote host [ipv4:192.168.31.24:50673] mapped to [[MicrosoftAccount]\[[email protected]](mailto:MicrosoftAccount]\[[email protected])]. local host [ipv4:192.168.31.45:445]
{"timestamp": "2020-03-20T15:07:23.116446+0200", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 1}, "eventId": 4625, "logonType": 3, "status": "NT_STATUS_NO_SUCH_USER", "localAddress": "ipv4:192.168.31.45:445", "remoteAddress": "ipv4:192.168.31.24:50673", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "[[email protected]](mailto:[email protected])", "workstation": "DESKTOP-SHFC62V", "becameAccount": null, "becameDomain": null, "becameSid": null, "mappedAccount": "[[email protected]](mailto:[email protected])", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 4816}}
Connection denied from ipv6:fe80::7d6e:2183:d0aa:d0a9:50676 to ipv6:fe80::ea11:32ff:fe01:8ab2:445
Auth: [SMB2,(null)] user [[MicrosoftAccount]\[[email protected]](mailto:MicrosoftAccount]\[[email protected])] at [Fri, 20 Mar 2020 15:07:27.940995 IST] with [NTLMv2] status [NT_STATUS_NO_SUCH_USER] workstation [DESKTOP-SHFC62V] remote host [ipv4:192.168.31.24:50677] mapped to [[MicrosoftAccount]\[[email protected]](mailto:MicrosoftAccount]\[[email protected])]. local host [ipv4:192.168.31.45:445]
{"timestamp": "2020-03-20T15:07:27.941161+0200", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 1}, "eventId": 4625, "logonType": 3, "status": "NT_STATUS_NO_SUCH_USER", "localAddress": "ipv4:192.168.31.45:445", "remoteAddress": "ipv4:192.168.31.24:50677", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "[[email protected]](mailto:[email protected])", "workstation": "DESKTOP-SHFC62V", "becameAccount": null, "becameDomain": null, "becameSid": null, "mappedAccount": "[[email protected]](mailto:[email protected])", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 3747}}
Connection denied from ipv6:fe80::7d6e:2183:d0aa:d0a9:50679 to ipv6:fe80::ea11:32ff:fe01:8ab2:445
Connection denied from ipv6:fe80::7d6e:2183:d0aa:d0a9:50681 to ipv6:fe80::ea11:32ff:fe01:8ab2:445
Auth: [SMB2,(null)] user [[MicrosoftAccount]\[[email protected]](mailto:MicrosoftAccount]\[[email protected])] at [Fri, 20 Mar 2020 15:07:32.783931 IST] with [NTLMv2] status [NT_STATUS_NO_SUCH_USER] workstation [DESKTOP-SHFC62V] remote host [ipv4:192.168.31.24:50682] mapped to [[MicrosoftAccount]\[[email protected]](mailto:MicrosoftAccount]\[[email protected])]. local host [ipv4:192.168.31.45:445]
{"timestamp": "2020-03-20T15:07:32.784097+0200", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 1}, "eventId": 4625, "logonType": 3, "status": "NT_STATUS_NO_SUCH_USER", "localAddress": "ipv4:192.168.31.45:445", "remoteAddress": "ipv4:192.168.31.24:50682", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "[[email protected]](mailto:[email protected])", "workstation": "DESKTOP-SHFC62V", "becameAccount": null, "becameDomain": null, "becameSid": null, "mappedAccount": "[[email protected]](mailto:[email protected])", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 4264}}
Auth: [SMB2,(null)] user [[MicrosoftAccount]\[[email protected]](mailto:MicrosoftAccount]\[[email protected])] at [Fri, 20 Mar 2020 15:07:33.809638 IST] with [NTLMv2] status [NT_STATUS_NO_SUCH_USER] workstation [DESKTOP-SHFC62V] remote host [ipv4:192.168.31.24:50684] mapped to [[MicrosoftAccount]\[[email protected]](mailto:MicrosoftAccount]\[[email protected])]. local host [ipv4:192.168.31.45:445]
{"timestamp": "2020-03-20T15:07:33.809795+0200", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 1}, "eventId": 4625, "logonType": 3, "status": "NT_STATUS_NO_SUCH_USER", "localAddress": "ipv4:192.168.31.45:445", "remoteAddress": "ipv4:192.168.31.24:50684", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "[[email protected]](mailto:[email protected])", "workstation": "DESKTOP-SHFC62V", "becameAccount": null, "becameDomain": null, "becameSid": null, "mappedAccount": "[[email protected]](mailto:[email protected])", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 4323}}
Connection denied from ipv6:fe80::7d6e:2183:d0aa:d0a9:50689 to ipv6:fe80::ea11:32ff:fe01:8ab2:445
