Hi (from france) !
i’m new in forum but i’ve got since months Pi3b+ with home assistant + Zwave.
some products zwave & wifi/RJ45 network products. After play with HA, i want to create proper cards and manage my home.
My first little question is why i’ve got always the same Kwh consumption on all power device (Smart Plug 16A par Qubino) ?
The entity ID is unique for each device, so having the exact same entity ID on each card results in the same values. Look up the differences under Config > Devices and Services > Entities, the last _2 will be incremented over the different included devices when not renamed.
Oh I misunderstood I guess. It seems like your devices are missing configuration to periodically send updated kWh values to association group 1. I’m not familiar with the Qubino devices but I suppose you can configure the device from within Home Assistant and enable V, A, W and kWh periodic updates in association group 1. Aside from the automatic updates when a value changes significantly (25 W or 5%).
Try configuring Parameter 42 to something like 600 seconds, see what happens after 10-15 minutes. The manual states that every increase of 0,1 kWh should trigger an update but maybe that’s not working for some reason.
After making the exclusion attempts, I tried to “remove the faulty device”, but I had a “ping …” error.
after the last update made today, i tried removing the failed device, and it just worked.
i think it’s a problem from migration old Z-wave to Z-Wave JS with the first ones qubino that i had installed.
