Folks - I’m trying to connect Sonoff Dongle P with a new install of HA.
I’ve done everything-
Flashed with router firmware using python
Added to USB 2.0 port on my laptop (running HAOS)
Distanced from other WiFi etc
Installed Z2M
Configured with/without MQTT User
Added/Removed MQTT server IP/port
Added Serial: port: /dev/ttyusb and also tried with /dev/id …
It just wouldn’t connect.
One thing I note is ZHA automatically tries to ask me to configure it at every restart but I just click ignore there. Logs are below. I have no idea what to do to get this going. ANY HELP appreciated. The issue seems to be that the dongle just won’t connect.
Logs
at Zigbee.start (/app/lib/zigbee.ts:69:27) at Controller.start (/app/lib/controller.ts:161:27) at start (/app/index.js:154:5) [19:09:50] INFO: Preparing to start... [19:09:50] INFO: Socat not enabled [19:09:51] INFO: Starting Zigbee2MQTT... Starting Zigbee2MQTT without watchdog. [2024-10-25 19:09:53] info: z2m: Logging to console, file (filename: log.log) [2024-10-25 19:09:53] info: z2m: Starting Zigbee2MQTT version 1.40.2 (commit #unknown) [2024-10-25 19:09:53] info: z2m: Starting zigbee-herdsman (2.1.3) [2024-10-25 19:09:53] error: zh:zstack:znp: Failed to determine if path is valid: 'Error: spawn udevadm ENOENT' [2024-10-25 19:09:53] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_72e680061d27ee11985583c1f49e3369-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false} [2024-10-25 19:09:53] info: zh:zstack:znp: Serialport opened [2024-10-25 19:09:53] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload [2024-10-25 19:09:54] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352 [2024-10-25 19:10:13] error: z2m: Error while starting zigbee-herdsman [2024-10-25 19:10:13] error: z2m: Failed to start zigbee [2024-10-25 19:10:13] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions [2024-10-25 19:10:13] error: z2m: Exiting... [2024-10-25 19:10:13] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:113:27) at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29) at Zigbee.start (/app/lib/zigbee.ts:69:27) at Controller.start (/app/lib/controller.ts:161:27) at start (/app/index.js:154:5)
