Samsung Family Hub - still not working
The family hub camera still doesn’t work. Any help would be appreciated.
Here’s the error log:
Log Details (ERROR)
Logger: aiohttp.server
Source: components/familyhub/camera.py:47
First occurred: 3:20:06 PM (54 occurrences)
Last logged: 3:28:57 PM
Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 123, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 492, in get
    return await self.handle(request, camera)
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 509, in handle
    image = await camera.async_camera_image()
  File "/usr/src/homeassistant/homeassistant/components/familyhub/camera.py", line 47, in async_camera_image
    return await self.family_hub_cam.async_get_cam_image()
  File "/usr/local/lib/python3.7/site-packages/pyfamilyhublocal/__init__.py", line 29, in async_get_cam_image
    glazeCameraInfo = await self._get_cam_info()
  File "/usr/local/lib/python3.7/site-packages/pyfamilyhublocal/__init__.py", line 57, in _get_cam_info
    data = json.loads(await response.read())
  File "/usr/local/lib/python3.7/json/__init__.py", line 348, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.7/json/decoder.py", line 337, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/local/lib/python3.7/json/decoder.py", line 355, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Same issue here. Have you ever found a solution or workaround?
Nope. I dont know how program. Hoping this integration can get fixed one day.
