Samsung Frame Art Mode
The problem is when my Nvidia Shield turns the Frame TV off it doesn’t go into art mode. If you use the Samsung remote of course it does. To keep the 1-remote simple life - I set an automation that triggers when the TV is turned off (in this case via CEC by the shield) the automation “turns the frame off” via the add-on below, which means it uses the “power button” that the Samsung remote would normally use, but the TV turns on again then off. I don’t understand why.
If you enable “Power button switch to art mode (Frame TV only)” advanced option in the add-on then you have to use the power button this is what I do:
  - type: turn_off
    device_id: xxx
    entity_id: xxx
    domain: remote
    enabled: true
I would like to use the service: samsungtv_smart.set_art_mode but I couldn’t get that to work on first pass so if anyone can share their automations that they used for https://github.com/ollo69/ha-samsungtv-smart this specific integration I’d love to see! Thanks
Or if they could tell me how to use it properly, I tried calling a service samsungtv_smart.set_art_mode but that didn’t work because maybe the TV is already off?
Perhaps post on ollo69’s GitHub?
Or check if the issue has already been reported and Closed?
Issue 1
Issue 2
Thanks for the links! I guess I don’t know if I’m doing it right, in other words am I the issue or an issue with the add-on
What addon? There is no addon.
I followed his installation instructions:
Installation
1. Easy Mode
Install via HACS.
That is not an addon then is it?
Oh I don’t know are we having a semantics discussion that is in no way a help to my problem? It’s not native to HASS so I thought add-on, do you have a solution to this issue?
As I said, post on ollo69’s GitHub, and/or read the threads pointed to by @ShadowFist .
I did that and ollo69 has not responded, and those threads don’t address exactly what I’m talking about. So, I thought I’d get some help here but the only one that wants to engage is a snarky replier which does not help the community
