Samsung integ wants Home Assistant Smartapp - what is it?
Hello, I’m trying to get my Samsung NU8000 (2018 model) to work with HA running on RPi 4. I’m adding the SmartThings integration in HA but it says:
Install SmartApp
Please install the Home Assistant SmartApp in at least one location and click submit.
Please ensure you have installed and authorized the Home Assistant SmartApp and try again.
What is that? I have SmartThings app on my iPhone, on the TV and Home Assistant app on the iPhone. I have no idea what “Home Assistant SmartApp” is and haven’t really found an answer.
Thanks!
It has been a while since I set this up myself, but revisiting the instructions:
In step #3-1, you pull up your SmartThings App on your iPhone (in this case its the “classic” i.e. original SmartThings App) and when you get to step #3-3 there should be a selection available for choosing Home Assistant (which is what they are calling the Home Assistant Smart App).
Thank you so much! “Home Assistant SmartApp” is quite far from “SmartThings Classic” :slight_smile:
