Samsung phone media player
I’ve loaded a blueprint that speaks out if this sensor or motion sensor etc. is activated. On.
When i select which media player there is only one. It’s the fire tablet running fully kiosk. It works and speaks as it should.
Companion app is on my s23 Ultra phone.
I’m using Home Assistant Cloud as the TTS. That and Google translate are also the only two options in that selection.
I also want it to speak on my Samsung S23 Ultra. It is not a media player option. There is none other than the fire tablet.
Any suggestions appreciated. Thanks in advance.
See: https://companion.home-assistant.io/docs/notifications/notifications-basic/#text-to-speech-notifications
Thank you, I’ve read it repeatedly and understand it if writing it my self. I guess it’s something in the Blueprint perhaps. I’ll keep looking and also asked the dev.
Yeah you’ll either have to create your own automation or blueprint to use this.
Thanks, I got it. Even an old guy can finally figure it out. If he has the right direction. I did read the docs several times, and it wasn’t clicking.:+1:
