Hi Guys, can you help me out how to fix the issue.
I have a nice Samsung 75" 2020 model smart TV
When i brought it a year ago it was working with HA, got it running with integration, almost all good.
After one HA update it stoped working, i cant get it running. I kept updating HA as new versions come out waiting to see this issue fix by itself. HA see it as a new device but i always get Failed to connect.
I tried other Samsung integrations using HACS, with no luck
I tried wireless and wired connections, i tried a new router with no changes. Although i can get the DLNA integration of it inside HA.
In settings of the TV i have WIFI controls and smart controls enabled.
I recenrly had my samsung tv not integrated properly. Turns out it had blocked access from HA. In the settings somewhere I was able to again allow access and reintegrate the tv from HA. I have a 2017 tv but I suspect the settings are the same. I’ll check back when I get a chance to look at the settings.
Edit: Here is the setting in Samsung Tizen. My tv is not in english, so this is my translation. Hope it makes sense.
It’s in settings - - > general - - > external device control - - > control of device connection (at the bottom) - - > device list. And then find and enable HomeAssistant.
Well i got a progress if that i can call
I went resetting my TV to default settings
It appeared and connected to HA, but it keeps pushing connect messages to HA every minute
Eaven if i say yes, i get the message again, so i turned the integration off
Known issue i guess
