Hi! My HA detects my Smsung tv as integration. When I confirm it I got a unkown error.
Log
2021-08-05 07:37:23 DEBUG (MainThread) [homeassistant.components.samsungtv] Samsung device found via ZEROCONF: {'host': '192.168.1.44', 'port': 43793, 'hostname': 'Samsung.local.', 'type': '_airplay._tcp.local.', 'name': 'Samsung Q60 Series (50)._airplay._tcp.local.', 'properties': {'_raw': {'acl': b'0', 'deviceid': b'70:B1:3D:18:F7:3D', 'features': b'0x7F8AD0,0x38BCB46', 'rsf': b'0x3', 'fv': b'p20.T-NKLDEUC-2014.1', 'flags': b'0x244', 'model': b'QTQ60E', 'manufacturer': b'Samsung', 'serialNumber': b'0EZS3HER600280K', 'protovers': b'1.1', 'srcvers': b'377.25.06', 'pi': b'04:7C:75:28:B4:B7', 'psi': b'00000000-0000-0000-0000-047C7528B4B7', 'gid': b'00000000-0000-0000-0000-047C7528B4B7', 'gcgl': b'0', 'pk': b'43c5642d28a43265398bcc8fc7d55a7e3d4f92d47a59be0b84d7b2d1299d322b'}, 'acl': '0', 'deviceid': '70:B1:3D:18:F7:3D', 'features': '0x7F8AD0,0x38BCB46', 'rsf': '0x3', 'fv': 'p20.T-NKLDEUC-2014.1', 'flags': '0x244', 'model': 'QTQ60E', 'manufacturer': 'Samsung', 'serialNumber': '0EZS3HER600280K', 'protovers': '1.1', 'srcvers': '377.25.06', 'pi': '04:7C:75:28:B4:B7', 'psi': '00000000-0000-0000-0000-047C7528B4B7', 'gid': '00000000-0000-0000-0000-047C7528B4B7', 'gcgl': '0', 'pk': '43c5642d28a43265398bcc8fc7d55a7e3d4f92d47a59be0b84d7b2d1299d322b'}}
2021-08-05 07:37:38 DEBUG (SyncWorker_4) [homeassistant.components.samsungtv] Try config: {'name': 'HomeAssistant', 'description': 'HomeAssistant', 'id': 'ha.component.samsung', 'host': '192.168.1.44', 'method': 'legacy', 'port': None, 'timeout': 31}
2021-08-05 07:37:38 DEBUG (SyncWorker_4) [homeassistant.components.samsungtv] Failing config: {'name': 'HomeAssistant', 'description': 'HomeAssistant', 'id': 'ha.component.samsung', 'host': '192.168.1.44', 'method': 'legacy', 'port': None, 'timeout': 31}, error: [Errno 111] Connection refused
2021-08-05 07:37:38 DEBUG (SyncWorker_4) [homeassistant.components.samsungtv] Try config: {'name': 'HomeAssistant', 'host': '192.168.1.44', 'method': 'websocket', 'port': 8002, 'timeout': 31}
2021-08-05 07:37:38 DEBUG (SyncWorker_4) [homeassistant.components.samsungtv] Failing config: {'name': 'HomeAssistant', 'host': '192.168.1.44', 'method': 'websocket', 'port': 8002, 'timeout': 31}, error: {'event': 'ms.channel.timeOut'}
2021-08-05 07:37:38 DEBUG (SyncWorker_4) [homeassistant.components.samsungtv] Try config: {'name': 'HomeAssistant', 'host': '192.168.1.44', 'method': 'websocket', 'port': 8001, 'timeout': 31}
2021-08-05 07:37:38 DEBUG (SyncWorker_4) [homeassistant.components.samsungtv] Failing config: {'name': 'HomeAssistant', 'host': '192.168.1.44', 'method': 'websocket', 'port': 8001, 'timeout': 31}, error: {'event': 'ms.channel.unauthorized'}
2021-08-05 07:37:38 DEBUG (SyncWorker_4) [homeassistant.components.samsungtv] No working config found
Any suggestions why it can’t find a working config?
