Good afternoon, I just can’t beat the problem with the integration of Samsung SmartTV
UE48J6300
`http://192.168.169.9:8001/api/v2/
"id": "uuid:f09f5ade-7f97-460f-b79d-32e19bbc4d87",
"name": "[TV] Small room",
"version": "2.0.25",
"device": {
"type": "Samsung SmartTV",
"duid": "uuid:f09f5ade-7f97-460f-b79d-32e19bbc4d87",
"model": "15_HAWKM_2D",
"modelName": "UE48J6300",
"description": "Samsung DTV RCR",
"networkType": "wired",
"ssid": "",
"ip": "192.168.169.9",
"firmwareVersion": "Unknown",
"udn": "uuid:f09f5ade-7f97-460f-b79d-32e19bbc4d87",
"resolution": "1920x1080",
"countryCode": "RU",
"msfVersion": "2.0.25",
"smartHubAgreement": "true",
"wifiMac": "f8:77:b8:df:06:e1",
"developerMode": "0",
"developerIP": ""
"uri": "http://192.168.169.9:8001/api/v2/"
Nmap 7.80
`Starting Nmap 7.80 ( https://nmap.org ) at 2020-01-12 12:41 RTZ 4 (ceia)
NSE: Loaded 151 scripts for scanning.
NSE: Script Pre-scanning.
Initiating NSE at 12:41
Completed NSE at 12:41, 0.00s elapsed
Initiating ARP Ping Scan at 12:41
Scanning 192.168.169.9 [1 port]
Completed ARP Ping Scan at 12:41, 0.46s elapsed (1 total hosts)
Initiating Parallel DNS resolution of 1 host. at 12:41
Completed Parallel DNS resolution of 1 host. at 12:41, 0.00s elapsed
Initiating SYN Stealth Scan at 12:41
Scanning 192.168.169.9 [1000 ports]
Discovered open port 8080/tcp on 192.168.169.9
Discovered open port 7676/tcp on 192.168.169.9
Discovered open port 8002/tcp on 192.168.169.9
Discovered open port 9999/tcp on 192.168.169.9
Discovered open port 9090/tcp on 192.168.169.9
Discovered open port 8001/tcp on 192.168.169.9
Discovered open port 8000/tcp on 192.168.169.9
Completed SYN Stealth Scan at 12:41, 0.17s elapsed (1000 total ports)
Initiating Service scan at 12:41
Scanning 7 services on 192.168.169.9
Completed Service scan at 12:42, 44.83s elapsed (7 services on 1 host)
Initiating OS detection (try #1) against 192.168.169.9
NSE: Script scanning 192.168.169.9.
Initiating NSE at 12:42
Completed NSE at 12:42, 11.03s elapsed
Completed NSE at 12:42, 0.38s elapsed
Completed NSE at 12:42, 0.00s elapsed
Nmap scan report for 192.168.169.9
Host is up (0.0012s latency).
Not shown: 993 closed ports
PORT STATE SERVICE VERSION
7676/tcp open upnp Samsung AllShare upnpd 1.0 (UPnP 1.1)
8000/tcp open http-alt
| fingerprint-strings:
| FourOhFourRequest, GetRequest, HTTPOptions:
| HTTP/1.1 500 Internal Server Error
| Content-Type: text/plain
| Date: Sun, 12 Jan 2020 07:41:59 GMT
|_ Connection: close
|_http-cors: GET POST PUT DELETE OPTIONS
|_http-favicon: Unknown favicon MD5: 33E3EA7FC9C08D2E72730482906A676C
| http-methods:
|_ Supported Methods: GET HEAD POST OPTIONS
|_http-open-proxy: Proxy might be redirecting requests
|_http-title: Site doesn't have a title.
8001/tcp open http Tizen Multiscreen SDK httpd
| http-methods:
|_http-title: 404 : Not Found
8002/tcp open ssl/http Tizen Multiscreen SDK httpd
|_http-cors: POST PUT DELETE
| http-methods:
| ssl-cert: Subject: commonName=SmartViewSDK/organizationName=SmartViewSDK/countryName=KR
| Subject Alternative Name: DNS:127.0.0.1, DNS:localhost
| Issuer: commonName=SmartViewSDK Root Ceritificate Authority/organizationName=SmartViewSDK/countryName=KR
| Public Key type: rsa
| Public Key bits: 2048
| Signature Algorithm: sha256WithRSAEncryption
| Not valid before: 2016-07-29T05:34:23
| Not valid after: 2036-07-29T05:34:23
| MD5: 189b 2634 fcca f1ef 31e1 7b7b 02ac c5bd
|_SHA-1: b15e 72c0 04b4 3825 651e e7a7 2b66 1856 305d e56b
|_ssl-date: TLS randomness does not represent time
| tls-nextprotoneg:
| http/1.1
|_ http/1.0
8080/tcp open http lighttpd
| http-methods:
|_ Supported Methods: OPTIONS GET HEAD POST
|_http-server-header: WebServer
|_http-title: 404 - Not Found
9090/tcp open http Samsung UE55D7000 TV http config
|_http-favicon: Unknown favicon MD5: D41D8CD98F00B204E9800998ECF8427E
| http-methods:
|_http-title: Site doesn't have a title (application/octet-stream).
9999/tcp open abyss?
1 service unrecognized despite returning data. If you know the service/version, please submit the following fingerprint at https://nmap.org/cgi-bin/submit.cgi?new-service :
SF-Port8000-TCP:V=7.80%I=7%D=1/12%Time=5E1ACDCD%P=i686-pc-windows-windows%
SF:r(GetRequest,78,"HTTP/1\.1\x20500\x20Internal\x20Server\x20Error\r\nCon
SF:tent-Type:\x20text/plain\r\nDate:\x20Sun,\x2012\x20Jan\x202020\x2007:41
SF::59\x20GMT\r\nConnection:\x20close\r\n\r\n")%r(FourOhFourRequest,78,"HT
SF:TP/1\.1\x20500\x20Internal\x20Server\x20Error\r\nContent-Type:\x20text/
SF:plain\r\nDate:\x20Sun,\x2012\x20Jan\x202020\x2007:41:59\x20GMT\r\nConne
SF:ction:\x20close\r\n\r\n")%r(HTTPOptions,78,"HTTP/1\.1\x20500\x20Interna
SF:l\x20Server\x20Error\r\nContent-Type:\x20text/plain\r\nDate:\x20Sun,\x2
SF:012\x20Jan\x202020\x2007:41:59\x20GMT\r\nConnection:\x20close\r\n\r\n");
MAC Address: F8:77:B8:DF:06:E1 (Samsung Electronics)
Device type: general purpose
Running: Linux 3.X
OS CPE: cpe:/o:linux:linux_kernel:3
OS details: Linux 3.2 - 3.10, Linux 3.2 - 3.16
Uptime guess: 1.491 days (since Sat Jan 11 00:55:22 2020)
Network Distance: 1 hop
TCP Sequence Prediction: Difficulty=260 (Good luck!)
IP ID Sequence Generation: All zeros
Service Info: Device: media device; CPE: cpe:/h:samsung:ue55d7000
TRACEROUTE
HOP RTT ADDRESS
1 1.23 ms 192.168.169.9
NSE: Script Post-scanning.
Read data files from: C:\Program Files (x86)\Nmap
OS and Service detection performed. Please report any incorrect results at https://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 61.86 seconds
Raw packets sent: 1023 (45.806KB) | Rcvd: 1020 (41.635KB)`
I used various costume components of various authors xchwarze / ha-samsungtv-custom, roberodin ha-samsungtv-custom, jaruba ha-samsungtv-custom. The result is one, only the actual status of the TV is displayed On / Off, but there is no control! Everything works only through port 8001. When using port 8002 in LOG
`Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/websocket/_socket.py", line 81, in recv
bytes_ = sock.recv(bufsize)
File "/usr/local/lib/python3.7/ssl.py", line 1056, in recv
return self.read(buflen)
File "/usr/local/lib/python3.7/ssl.py", line 931, in read
return self._sslobj.read(len)
socket.timeout: The read operation timed out
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 407, in _async_add_entity
await entity.async_update_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 284, in async_update_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 327, in _async_write_ha_state
attr.update(self.state_attributes or {})
File "/usr/src/homeassistant/homeassistant/components/media_player/__init__.py", line 795, in state_attributes
for attr in ATTR_TO_PROPERTY
File "/usr/src/homeassistant/homeassistant/components/media_player/__init__.py", line 796, in <dictcomp>
if getattr(self, attr) is not None
File "/config/custom_components/samsungtv_custom/media_player.py", line 286, in source_list
self._gen_installed_app_list()
File "/config/custom_components/samsungtv_custom/media_player.py", line 248, in _gen_installed_app_list
app_list = self._remote.app_list()
File "/usr/local/lib/python3.7/site-packages/samsungtvws/remote.py", line 175, in app_list
self._ws_send(payload)
File "/usr/local/lib/python3.7/site-packages/samsungtvws/remote.py", line 89, in _ws_send
self.open()
File "/usr/local/lib/python3.7/site-packages/samsungtvws/remote.py", line 104, in open
sslopt=sslopt
File "/usr/local/lib/python3.7/site-packages/websocket/_core.py", line 511, in create_connection
websock.connect(url, **options)
File "/usr/local/lib/python3.7/site-packages/websocket/_core.py", line 223, in connect
self.handshake_response = handshake(self.sock, *addrs, **options)
File "/usr/local/lib/python3.7/site-packages/websocket/_handshake.py", line 79, in handshake
status, resp = _get_resp_headers(sock)
File "/usr/local/lib/python3.7/site-packages/websocket/_handshake.py", line 150, in _get_resp_headers
status, resp_headers, status_message = read_headers(sock)
File "/usr/local/lib/python3.7/site-packages/websocket/_http.py", line 298, in read_headers
line = recv_line(sock)
File "/usr/local/lib/python3.7/site-packages/websocket/_socket.py", line 102, in recv_line
c = recv(sock, 1)
File "/usr/local/lib/python3.7/site-packages/websocket/_socket.py", line 84, in recv
raise WebSocketTimeoutException(message)
websocket._exceptions.WebSocketTimeoutException: The read operation timed out`
On costume components of the author xchwarze, the token-192.178.189.9.txt file is created in the folder, but it is empty! The TV does not issue a request for granting access to work with HA on any component, I think this is the main problem, but how to send a request for granting access if nothing happens when you click on the Sound, Channel, Source buttons (
P.s
I also checked on which port the standard Samsung TV Android application accesses via TV via Wireshark. Handling and control occurs via port 8001 with a token request on the TV screen
