Hello, I’ve a 2019 55Q60 and jaruba repo works almost fine, the only problem I’m facing is that I get a notification every 10 seconds in my TV asking for permissions that I’ve already accepted. Also I deactivate notifications from the TV and stills showing…
What works: select TV or Youtube App as Input, turn on and off and basic controls.
What does not work: select a specific HDMI channel as Input.
Questions:
How can I select a specific HDMI channel?
How can I obtain the app IDs for other apps like Youtube?
Also, can somebody link me how to add some custom buttons to lovelace or the media-control-card? The default card only features few buttons like play, pause, on, off etc.
Changelog:
Add debug info for help in creation of custom app_list
Add ON command support for legacy TVs (port 8001)
Add KEY_HDMI_FIX virtual key for emulate a double KEY_HDMI key press
Until Samsung does not publish all the commands of ms.remote.control this is all that can be done
@xchwarze now that the component that’s bundled in has been rewritten, with config flow and all, any chance to convince you to contribute to it so that it uses your library and supports more models?
Reply to my own post… I still have this exact same issue with the latest (HACS installed) component. Tv only goes on, all other services I call gives me an approve promt on the tv but nothing happens… any hint?
Hi all, i tried to install the custom version but no luck…it says this addon is not official.
i have an app called smart view for samsung which works, so commands over wifi work fine,any idea how to have HA working?
i red loads of post but with no luck of which procedure i should follow.
Same no luck for broadlink rm mini 3… impossible for me to have it working…
If anyone can help would be really appreciated
thanks
update reset rm3 and works with broadlink , i stich with this until samsung tv will be fixed
RM Mini 3
Reset the device , reconfigured , it learn and send commands!
Samsung tv , still no luck…
If someone want to try to understand commands
On app store there is an app called samsung smart view… this works flawless as a remote through wifi…
