After updating to 0.93.1 I get the following error in the log. Someone knows what it indicates?
Prior to the update syncthru worked fine with my samsung printer. Now it seems that the “tray_1” sensor and at least one more is missing.
[homeassistant.config] Invalid config for [sensor.syncthru]: value is not allowed @ data[‘monitored_conditions’][1]. Got ‘tray_1’. (See /home/homeassistant/.homeassistant/sensors.yaml, line 212). Please check the docs at https://home-assistant.io/components/sensor.syncthru/
Yes I confirm the behaviour. I have the same message on this previously working tag.
Also for whatever reason the other tags don’t update anymore (toner_black and status) for my syncthru device (Samsung Laser printer)
> ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.syncthru]: value is not allowed @ data['monitored_conditions'][4]. Got 'tray_1'
> value is not allowed @ data['monitored_conditions'][5]. Got 'output_tray_0'.
I have noticed that the latest version of syncthru from 24th of April makes the toner level disapear. I have tried to put a custom component with the preious version of the 12th of April and the toner level appears again.
Toner level is working fine for me. The problem I have is for output_tray_* and tray_*.
But this April 24th version added a (involuntary?) breaking change in the name of the config parameters for monitored_conditions:
tray_* became trays_* output_tray_* became output_trays_*
So, for the moment, if you want to have it working, just add a ‘s’ to “tray”.
EDIT: adding a ‘s’ will make config validation OK, but there is still an inconsistency in the code that won’t make these sensors reappear. I’ve added a comment in the code review to notify author about that.
Toner level shows fine in syncthru but not i HA.
Adding a “s” to “tray_1” --> “trays_1” makes the error dissapear but only “sensor.samsung_printer” seems to Work.
Samsung C430W worked fine. Now all I get is in the Log:
[homeassistant.loader] Loaded syncthru from homeassistant.components.syncthru
[homeassistant.components.sensor] Setting up sensor.syncthru
[homeassistant.components.syncthru.sensor] Discovered a new Samsung Printer at 192.168.1.9
Same issue here. My config in sensor.yaml is nearly identical to yours and everything is “unknown” even tho syncthru web service is reporting everything.
As @Lefuneste pointed out previously, this issue comes from an update to the syncthru component in HA. I already added a comment in the changeset, but I’m not sure it has been seen. It would be best to file a new issue with HA.
