I can not get the token from tv
root@nuci5:~/ha-samsungtv-encrypted/custom_components/samsungtv_encrypted# python3 get_token.py -ip 192.168.1.118 -port 8000
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 60, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.6/socket.py", line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name or service not known
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 357, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.6/http/client.py", line 1254, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/lib/python3.6/http/client.py", line 1300, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/lib/python3.6/http/client.py", line 1249, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.6/http/client.py", line 1036, in _send_output
self.send(msg)
File "/usr/lib/python3.6/http/client.py", line 974, in send
self.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 166, in connect
conn = self._new_conn()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f66809fd358>: Failed to establish a new connection: [Errno -2] Name or service not known
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='p', port=8000): Max retries exceeded with url: /socket.io/1/?t=1584881659537 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f66809fd358>: Failed to establish a new connection: [Errno -2] Name or service not known',))
File "get_token.py", line 27, in <module>
main(sys.argv[1:])
File "get_token.py", line 24, in main
PySmartCrypto(ip, port)
File "/root/ha-samsungtv-encrypted/custom_components/samsungtv_encrypted/PySmartCrypto/pysmartcrypto.py", line 123, in __init__
self._connection = self.connect()
File "/root/ha-samsungtv-encrypted/custom_components/samsungtv_encrypted/PySmartCrypto/pysmartcrypto.py", line 95, in connect
websocket_response = requests.get(step4_url)
File "/usr/lib/python3/dist-packages/requests/api.py", line 72, in get
return request('get', url, params=params, **kwargs)
File "/usr/lib/python3/dist-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 520, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 630, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='p', port=8000): Max retries exceeded with url: /socket.io/1/?t=1584881659537 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f66809fd358>: Failed to establish a new connection: [Errno -2] Name or service not known',))
