I need have a look of this.
Please, could you open a ticket with this information in https://github.com/sermayoral/ha-samsungtv-encrypted/issues?
I cant get the get_token.py to work…
I’v installed successfully websocket and websocket-client in a Raspbian Environment.
But when i execute
python3 get_token.py --ip 192.168.178.24 --port 8080
ill get the following error:
File "get_token.py", line 3, in <module>
from PySmartCrypto.pysmartcrypto import PySmartCrypto
File "/home/pi/Downloads/ha-samsungtv-encrypted/custom_components/samsungtv_encrypted/PySmartCrypto/pysmartcrypto.py", line 8, in <module>
import websocket
ImportError: No module named 'websocket'
Do you know any further troubleshooting?
I’v tried to reinstall the websocket module. Now i’ll get different error:
ws://192.168.178.24:8000/socket.io/1/websocket/vr1LvV1xjmMmtiOcAOkn
File "get_token.py", line 27, in <module>
main(sys.argv[1:])
File "get_token.py", line 24, in main
PySmartCrypto(ip, port)
File "/home/pi/Downloads/ha-samsungtv-encrypted/custom_components/samsungtv_encrypted/PySmartCrypto/pysmartcrypto.py", line 123, in __init__
self._connection = self.connect()
File "/home/pi/Downloads/ha-samsungtv-encrypted/custom_components/samsungtv_encrypted/PySmartCrypto/pysmartcrypto.py", line 99, in connect
connection = websocket.create_connection(websocket_url)
AttributeError: module 'websocket' has no attribute 'create_connection'
It’s work
pip3 install websocket
pip3 install websocket-client
python3 get_token.py -i 192.168.x.x -p 8080
Never used Python before so apologies
I have installed Python 3.8 from https://www.python.org/ onto my Win10 PC
I then went to open get_token.py and get
I then run module and get
How do I install the module Cypto?
I have tried
pip3 install pycrypto
get
Regards,
Hi, you must run this outside of the Python shell. Like normal Windows Command Line or so.
Yeah I figured that out myself, thanks, however…
warning: GMP or MPIR library not found; Not building Crypto.PublicKey._fastmath.
building 'Crypto.Random.OSRNG.winrandom' extension
error: Microsoft Visual C++ 14.0 is required. Get it with "Microsoft Visual C++ Build Tools": https://visualstudio.microsoft.com/downloads/
ERROR: Command errored out with exit status 1: 'c:\users\mark\appdata\local\programs\python\python38-32\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\Mark\\AppData\\Local\\Temp\\pip-install-kk7uu6hv\\pycrypto\\setup.py'"'"'; __file__='"'"'C:\\Users\\Mark\\AppData\\Local\\Temp\\pip-install-kk7uu6hv\\pycrypto\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\Mark\AppData\Local\Temp\pip-record-zoj54f0c\install-record.txt' --single-version-externally-managed --compile --install-headers 'c:\users\mark\appdata\local\programs\python\python38-32\Include\pycrypto' Check the logs for full command output.
C:\Users\Mark>
Had a look at https://visualstudio.microsoft.com/visual-cpp-build-tools/ but do not know what packages I need?
Now I have got this far…
C:\Users\Mark>pip install crypto.py
Collecting crypto.py
Downloading Crypto-Py-0.0.4.tar.gz (4.3 kB)
Requirement already satisfied: pycryptodome in c:\users\mark\appdata\local\programs\python\python38-32\lib\site-packages (from crypto.py) (3.9.7)
Installing collected packages: crypto.py
Running setup.py install for crypto.py ... done
Successfully installed crypto.py
C:\Users\Mark>python get_token.py
ModuleNotFoundError: No module named 'PySmartCrypto'
Okay,
Some success after a lot of Googling.
I am Running Win 10 and Python 3.8.2
From the command line
pip install crypto
Renamed folder crypto to Crypto
help (“modules”)
Python 3.8.2 (tags/v3.8.2:7b3ab59, Feb 25 2020, 22:45:29) [MSC v.1916 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> help ("modules")
Please wait a moment while I gather a list of all available modules...
Crypto _tracemalloc gevent sched
Crypto_Py _warnings glob secrets
Naked _weakref greenlet select
__future__ _weakrefset gzip selectors
_abc _winapi hashlib setuptools
_ast _xxsubinterpreters heapq shellescape
_asyncio _yaml hmac shelve
_bisect abc html shlex
_blake2 aifc http shutil
_bootlocale antigravity idlelib signal
_bz2 argparse idna site
_cffi_backend array imaplib six
_codecs ast imghdr smtpd
_codecs_cn asynchat imp smtplib
_codecs_hk asyncio importlib sndhdr
_codecs_iso2022 asyncore inspect socket
_codecs_jp atexit io socketserver
_codecs_kr audioop ipaddress sqlite3
_codecs_tw base64 itertools sre_compile
_collections bdb json sre_constants
_collections_abc binascii keyword sre_parse
_compat_pickle binhex lib2to3 ssl
_compression bisect linecache stat
_contextvars builtins locale statistics
_csv bz2 logging string
_ctypes cProfile lzma stringprep
_ctypes_test calendar mailbox struct
_datetime certifi mailcap subprocess
_decimal cffi marshal sunau
_dummy_thread cgi math symbol
_elementtree cgitb mimetypes symtable
_functools chardet mmap sys
_hashlib chunk modulefinder sysconfig
_heapq cmath msilib tabnanny
_imp cmd msvcrt tarfile
_io code multiprocessing telnetlib
_json codecs netrc tempfile
_locale codeop nntplib test
_lsprof collections nt textwrap
_lzma colorsys ntpath this
_markupbase compileall nturl2path threading
_md5 concurrent numbers time
_msi configparser opcode timeit
_multibytecodec contextlib operator tkinter
_multiprocessing contextvars optparse token
_opcode copy os tokenize
_operator copyreg parser trace
_osx_support crypt pathlib traceback
_overlapped csv pdb tracemalloc
_pickle ctypes pickle tty
_py_abc curses pickletools turtle
_pydecimal dataclasses pip turtledemo
_pyio datetime pipes types
_queue dbm pkg_resources typing
_random decimal pkgutil unicodedata
_sha1 difflib platform unittest
_sha256 dis plistlib urllib
_sha3 distutils poplib urllib3
_sha512 doctest posixpath uu
_signal dummy_threading pprint uuid
_sitebuiltins easy_install profile venv
_socket email pstats warnings
_sqlite3 encodings pty wave
_sre ensurepip py_compile weakref
_ssl enum pyclbr webbrowser
_stat errno pycparser websocket
_statistics faulthandler pydoc winreg
_string filecmp pydoc_data winsound
_strptime fileinput pyexpat wsgiref
_struct fnmatch queue xdrlib
_symtable formatter quopri xml
_testbuffer fractions random xmlrpc
_testcapi ftplib re xxsubtype
_testconsole functools reprlib yaml
_testimportmultiple gc requests zipapp
_testmultiphase genericpath rlcompleter zipfile
_thread getopt runpy zipimport
_threading_local getpass samsungtv zlib
_tkinter gettext samsungtv_encrypted
Enter any module name to get more help. Or, type "modules spam" to search
for modules whose name or summary contain the string "spam".
Thanks spectreman.
In my instance python get_token.py -i 192.168.0.220 -p 8080
C:\Users\Mark\samsungtv_encrypted>python get_token.py -i 192.168.0.220 -p 8080
ws://192.168.0.220:8000/socket.io/1/websocket/6gpWDaiHEcrt8Mz1AT2m
Current state: stopped
Pin NOT on TV
Please enter pin from tv: 3429
Got pin: '3429'
AES key: 8989b4ab2b11de2490047c598e9cdef0
AES encrypted: 783434f279c10da6ff7d03ed79a89a037974baf448a02e6914997da0d2347b64d6fecc3f2212f9f860c4cd2208458b1016524c1c0db922851cdeaa3014449f7ea702200fa7fba43b63834c798b5af313b6a0d741f89c5d4e08dad1965317b63ab69139fdc10a1859de7d1c9004f8d3cdf845fa4debba94a7904b748bad4034bb
AES swapped: ad9110eaef370f4cb8112a51400d632a6e93aa64286dcf1a0ffa23b72b7f023532e00861597812f22d0d7bb68eac7507706ee8f43d866cfda0cb522a44124941d74f2f94de142ef6575ccb8af846a4ad23ce78a3b041080231f4648f9f40232c365691c846c7adc53c602836582f95255b45f1fd782911345b0385087e4a2035
data buffer: 00000006363534333231AD9110EAEF370F4CB8112A51400D632A6E93AA64286DCF1A0FFA23B72B7F023532E00861597812F22D0D7BB68EAC7507706EE8F43D866CFDA0CB522A44124941D74F2F94DE142EF6575CCB8AF846A4AD23CE78A3B041080231F4648F9F40232C365691C846C7ADC53C602836582F95255B45F1FD782911345B0385087E4A2035
hash: 4ccc3fca9f35151d377c636da7b0f8f8d7fe68be
secondStepResponse: {"auth_data":"{\"auth_type\":\"SPC\",\"request_id\":\"0\",\"GeneratorClientHello\":\"010100000000000000009E0000000636353433323169A8EBD90978638E213D716ADC94C47AF6203514584D730C035EE57DA27CA8AAC3A0E40C6AF2E2536647919F543991A941C714FAA371FBA6407B3A2941B48AA72F7A029DDB202FBC2739191258A9ECDBE42363B74AFE52D3DDA290C9417B285E9063366FA2A6776152C5B024FBFAE8252FE76A5FF7A319C6AB71A08C450AF08424577B7138886B507E574650E1B59DD56CB356DE0000000000\"}"}
thirdLen: 138
hello: 010100000000000000009e0000000636353433323169a8ebd90978638e213d716adc94c47af6203514584d730c035ee57da27ca8aac3a0e40c6af2e2536647919f543991a941c714faa371fba6407b3a2941b48aa72f7a029ddb202fbc2739191258a9ecdbe42363b74afe52d3dda290c9417b285e9063366fa2a6776152c5b024fbfae8252fe76a5ff7a319c6ab71a08c450af08424577b7138886b507e574650e1b59dd56cb356de0000000000
dest: 0000000636353433323169a8ebd90978638e213d716adc94c47af6203514584d730c035ee57da27ca8aac3a0e40c6af2e2536647919f543991a941c714faa371fba6407b3a2941b48aa72f7a029ddb202fbc2739191258a9ecdbe42363b74afe52d3dda290c9417b285e9063366fa2a6776152c5b024fbfae8252fe76a5ff7a319c6ab71a08c450af0844ccc3fca9f35151d377c636da7b0f8f8d7fe68be
userId: 654321
pEncWBGx: 69a8ebd90978638e213d716adc94c47af6203514584d730c035ee57da27ca8aac3a0e40c6af2e2536647919f543991a941c714faa371fba6407b3a2941b48aa72f7a029ddb202fbc2739191258a9ecdbe42363b74afe52d3dda290c9417b285e9063366fa2a6776152c5b024fbfae8252fe76a5ff7a319c6ab71a08c450af084
pEncGx: 1a3a68b685d34a85cd150e73332e9061e0960640103c2d3f79205f0f6ae011e8714b3390bca129015cd8be207d59243458ae9b19f7caa16b1050e037fa3f5c8339cd7309b86b78147f29a706680a4e3cfb135ec52474d97923764344dc39a50bb76a9cc9ab23186d0f794165c9eda3b256c186845e2e74b46d5f9fdd8a1e3150
pGx: 3c22063ce58b5b80cd75cd815e8ed4a33a09832d7cc458e56643de16cd261fdb70bc051a45afceef4740167fd19dc19adff491e536e8f84f2ca762f5379368a15a5f67ee2a02f8797933cd775e2fcdc902e327d37ecea81b1968f35885212412bff8ddb583c266e9b204d260dd95e7fa709352638a3f78cd4905a48b7e7639fa
secret: 3c3d855035feda1654dc344fbc260bd9f1ce369b2bd8f4c04658b6fb9ca4210c49a9b10af7dc2592b1960d17bc09e15ee13db639baf64c6548fd65d24f151c9d26c773a25fa8cba840410568a374a3662be3e9969c12a893438582a50afc3f7dd006bcbe890fca39646014f1faa086da3d15d214dc37c3e75d13f11005bbd440
hash2: 24577b7138886b507e574650e1b59dd56cb356de
secret2: 3635343332313c3d855035feda1654dc344fbc260bd9f1ce369b2bd8f4c04658b6fb9ca4210c49a9b10af7dc2592b1960d17bc09e15ee13db639baf64c6548fd65d24f151c9d26c773a25fa8cba840410568a374a3662be3e9969c12a893438582a50afc3f7dd006bcbe890fca39646014f1faa086da3d15d214dc37c3e75d13f11005bbd440
hash3: 24577b7138886b507e574650e1b59dd56cb356de
Pin OK :)
dest_hash: 767c3ddedd58078e2e77a6e4add8e4f5e2256cec
SKPrime: 71d7d03ca00735caf80cd5232f49c36245d6ce0f
SKPrimeHash: 1dfcae0b1774a1fb38789d6b9306a76365eaee4f
ctx: a8dcf55ae255075c660243d53ea05093
Pin accepted :)
sessionId: 2
SessionID: 2
Authorization successfull :)
so my configuration.yaml
media_player:
- platform: samsungtv_encrypted
host: 192.168.0.220
token: a8dcf55ae255075c660243d53ea05093
sessionid: 2
port: 8080
Hope this helps others.
I can control the Source, Volume and Switch Off functions, is there a way to switch on?
Regards,
The only way you can turn on your TV is connecting your Home Assistant Device to your TV using a HDMI cable, and using the hdmi version of the component: https://github.com/sermayoral/ha-samsungtv-encrypted/releases/tag/v2.3-hdmi
These encrypted models don’t support turning on using LAN
Official samsungtv integration supports turn_on_action
option, which can be set to any action. Is that possible to add the same here? I have IR remote and easily can turn tv on using it.
Hi Mark, I’m unable to do as you…
I installed Python 3.8.3 for Python.org, I can open the shell and everything seem good.
But from my command line when I enter pip install crypto I had the error that “pip” is not recognized as command or program…
Can you help?
Hi, im nubby of python…
I’m trying to install the tv on hassio, I installed python on the windows’s laptop I followed the whole conversation and when I try to give the following commands I get this error … what can I try?
Did you do the following?
Regards,
Yes many time …
well i tryed many road, at the end
the script say me:
current state stoped
pin NOT on tv…
i run on samsung tv h6203
what can i also try?
thank you so much
Hey! Have you seen my message about adding turn_on_action
option? Is that possible that you’ll work on that?
