Samsung TV no longer turns on - error
I used to be able to turn on/turn off my Samsung TV (UN55HU8550) and it was successfully setup within devices. I am now getting an error:
When I take a look at the logs I see:
Logger: homeassistant.components.samsungtv
Source: helpers/update_coordinator.py:382
integration: Samsung Smart TV (documentation, issues)
First occurred: June 27, 2025 at 8:39:41 PM (265 occurrences)
Last logged: 2:26:16 AM
Unexpected error fetching samsungtv data
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 382, in _async_refresh
    self.data = await self._async_update_data()
  File "/usr/src/homeassistant/homeassistant/components/samsungtv/coordinator.py", line 53, in _async_update_data
    self.is_on = await self.bridge.async_is_on()
  File "/usr/src/homeassistant/homeassistant/components/samsungtv/bridge.py", line 427, in async_is_on
    if remote := await self._async_get_remote():
  File "/usr/src/homeassistant/homeassistant/components/samsungtv/bridge.py", line 461, in _async_get_remote
    return await self._async_get_remote_under_lock()
  File "/usr/src/homeassistant/homeassistant/components/samsungtv/bridge.py", line 813, in _async_get_remote_under_lock
    assert self.port
AssertionError
I can’t make sense of what is going on. I’ve tried re-adding the integration and this error pops up each time. Stumped to what is going on. Any help would be appreciated!
Did it recently software update?
What software version is Tv using?
This integration requires TV to be ON when HA reboot to establish connection. I don’t think it will connect without HA rebooting.
I think I have same model so maybe I will check. I use CEC and control TV through roku integration
That’s the only thing I can think of. The software on the TV didn’t update (it’s from 2013 (lol) and hasn’t had updates in years. The only thing is HA version changed over that time.
I just started getting that error in the last few days and I haven’t been tinkering in HA to any deep extent.
What version of ha are you on? There were some bugs and changes lately.
How did you get CEC to work on yours? I was just thinking of doing that but for whatever reason, the Roku turns on but the TV won’t
Just works.
You may need my to turn off one of the energy save features or use specific input. What is model#.
It controls basics like volume and power but TV must have CEC function which most do.
The weirdest thing i can’t figure out is how the integration allows me to turn off the TV but won’t allow me to turn it on. I was finally able to get at least it partially working.
It feels like if one works, why shouldn’t the opposite function work as well. I do have AnyCEC (I am not in front of my TV at the moment, so may have the nomenclature wrong), but I still can’t figure out the bug or the conflict that would prevent the TV turning on.
Menu >> system >> eco solution >> energy saving [OFF]
There is a cpu that controls advanced function in TV. Ethernet, advanced image processing and communications to the chip that controls power on\Off. all power save features turn that off to save power when tv is off. Well, that means you can’t remotely turn on tv over WiFi.
My model is old but I bet if you find that and turn it off “power on” over network may work
I think CEC is basically part of hdmi spec. Most TVs have it. You may need to enable it.
Thanks for the suggestion! I did check this on my TV and all those functions (under Eco) are turned off. (I previously even factory reset my TV settings to see if that would help, but alas, no). The only thing I have turned on in my settings is CEC now. I even ruled out anything with Google Home integration (tried turning my TV on and off via HA console - turning off works, but not turning on). Very strange!
Via integration or CEC?
Via integration. sorry I should have made that clearer. When I toggle it in HA the TV will turn off but not on.
I don’t use integration so can’t speak on it. You can try looking at log to verify command being sent if possible. What model # TV?
CEC Off/on works
EDIT
I think on never worked when I used integration as well. Unused CEC to turn on so it was never an issue. It was long time ago but I thinking remember that.
So I guess the integration uses wake on LAN to turn on the TV. This only works if it know the mac of the TV.
You can use below for
  1. Test to see if wake on lan will work for you TV
  2. If Samsung integration doesnt work you can just use this instead. It’s recommended in the docs.
# Example configuration.yaml entry
wake_on_lan: # enables `wake_on_lan` integration
automation:
  - alias: "Turn On Living Room TV with WakeOnLan"
    triggers:
      - trigger: samsungtv.turn_on
        entity_id: media_player.samsung_smart_tv
    actions:
      - action: wake_on_lan.send_magic_packet
          mac: aa:bb:cc:dd:ee:ff
