i have the samsung smart tv QE65Q60AAUXXH and i added on homeKit but i want to control the volum up/down, change channels mode HDMI etc. i like that now
how can do this to like as LG remote controller?
As I know this is not possible yet. It‘s only possible to switch the sources but not more. You can publish the volume as a light or fan but this is not a good solution.
ok i see thank you!
There is a custom integration called SamsungTV Smart. It works for mine although I have no control of the inputs. My TV is from 2016 though.
and you have volum up/down and channels?
you write code on configuration.yaml? bcs mine have only turn on/off, TV and HDMI
I guess the integration has nothing to do with apple home.
the tv need to be on the LAN? bcs i have wifi and dont turn on.
