After installing a PiHole on my network, I discovered my Samsung TV (The frame 65" 2021) doing a ton of reverse DNS requests for my Home Assistant (local) IP address. As you can see, this happens continuously every ~10 seconds.
My TV is connected to Home Assistant directly using the Samsung integration. Not through Smart Things.
Does anyone see the same behaviour or know how to mitigate this? It pretty much fills up my PiHole with logs and bandwidth…
