Samsung TV (The Frame) sometime to volume 100
Since a while when I activate a “scene” (just a flow of actions) via node-red my Samsung TV is set to max volume (100!). The volume of the TV is just set to maximum.
It’s not always. And there is no configuration at all for the TV in the scene (!).
I use the native integration:
There is no logging and no error, no history, nothing. Just sometime a volume max to 100…
What and how can this be and/or how to troubleshoot this…
Post the flow
There is no flow 🤷 it seems to be related to recent updates… cpuld it be dlna related or so?
You said you have a scene that you turn on…. I don’t know the NR terminology, just post that scene
Yes but it really adds nothing… there are no references to a tv. Just lamps 🤷🙆‍♂️
In the same vein, HA isn’t going to randomly call a service to change the volume on a tv, but you’re asking the question. I’m just trying to help by seeing all the parts of the equation.
Believe that. But nothing changed in 4 years to this and suddenly it happens… So I think it must do “something”… But I have no inclusion of TC automation at all, only integration
Can you please post the scene.
Yesterday it did not happen…
[{"id":"57c92285378e1efc","type":"api-call-service","z":"6f59380a.4fad78","name":"Tuin_A_Spot_5 Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.tuin_a_spot_5"],"data":"{\"brightness\":255,\"rgb_color\":[127, 255, 0]}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1400,"y":860,"wires":[["919005002d90e3e3"]]},{"id":"919005002d90e3e3","type":"api-call-service","z":"6f59380a.4fad78","name":"Tuin_A_Spot_6 Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.tuin_a_spot_6"],"data":"{\"brightness\":255,\"rgb_color\":[255, 119, 75]}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1620,"y":860,"wires":[["6d39dabd7ed7ec61"]]},{"id":"6d39dabd7ed7ec61","type":"api-call-service","z":"6f59380a.4fad78","name":"Tuin_A_Spot_7 Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.tuin_a_spot_7"],"data":"{\"brightness\":255,\"rgb_color\":[255, 191, 0]}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1840,"y":860,"wires":[["453e19ba8e0146d0"]]},{"id":"820b331503bb5fe0","type":"group","z":"6f59380a.4fad78","style":{"stroke":"#2e333a","stroke-opacity":"1","fill":"#383c45","fill-opacity":"0.5","label":true,"label-position":"nw","color":"#dddddd"},"nodes":["b0238c47.6446c8","7199a5a7.a5cb2c","61644f61.2fefa","93b356e1.bf8b48","6a57690c.2236f8","3f2675ac.61446a","ebfa90e7.59d2d8","935a99b9.140318","817c0f7d.7fa6a","f60634a8.09d21","3a9ed548.21f602","d3555d03.4f6d88","56398df5.04c4cc","8ceface8.f1df3","52c4fa0d.5a2254","80d5e65a.87c548","be5705c8.156e3","aaea4172.b7083","facb8043.8c3f48","3c93bb44.89aca4","ea99117d.759f5","f1629fc1.5d2b18","d21fc9de.db2d38","60146cfe.b8424c","c1b64cc7.10cea","e6620353.63267","fef32967.b58a4","3cbad8e1.fbf658","5cb54289.40448c","e99518ea.60b82","dbaa23c6.36e59","cf3b59b16fb17105","3ce2ab917f8e3f2a","d98ee1d074ec7e68","fa0fe2e6f42263d6","876420bdca9d8e60","10cc4a239fd6de11","6f380720.197a3","29f48820f1c9805c","361433da.39584c","294d8fe496c3ebad","c40355c5.227a28","39f5b348.b857ec","50e3c24e.779d6c","b5907f94.072d18","a8cc5043a6b7f88d","449d2fc0.57581","3fffb59b.560db2","e10bdedf.b8061","8f8edc62.08e4b8","a4cae1bce92ffcd9","49b1bae6.bd7f6c","e609437a.6a9bf8","30e793a8.cd7c3c","844e62f12948d401","bae8d96e9b009397","edd16f99fe226cc2","db9610e9b099bd01","bb360d46a46c17fe","453e19ba8e0146d0"],"x":45,"y":719,"w":2181,"h":719},{"id":"b0238c47.6446c8","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Turn on Bol Woonkamer - 50 - LichtOranje","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.bol_woonkamer"],"data":"{\"entity_id\":\"light.bol_woonkamer\",\"brightness\":\"50\",\"rgb_color\":[ 255, 180, 91]}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":577,"y":954,"wires":[[]]},{"id":"7199a5a7.a5cb2c","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Rooluik Slaapkamer 17%","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.rolluik_slaapkamer_groot_156"],"data":"{\"entity_id\":\"cover.rolluik_slaapkamer_groot_156\",\"position\":\"17\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":829,"y":1197,"wires":[[]]},{"id":"61644f61.2fefa","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Rooluik Slaapkamer Dicht","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"cover","service":"close_cover","areaId":[],"deviceId":[],"entityId":["cover.rolluik_slaapkamer_groot_156"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":829,"y":1149,"wires":[[]]},{"id":"93b356e1.bf8b48","type":"api-current-state","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Temp Schuur Voordeur <8","server":"c6b350c5.b8b3c","version":3,"outputs":2,"halt_if":"8","halt_if_type":"num","halt_if_compare":"lt","entity_id":"sensor.zw100_multisensor_6_air_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":529,"y":1155,"wires":[["61644f61.2fefa"],["7199a5a7.a5cb2c"]]},{"id":"6a57690c.2236f8","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Turn on Bol Woonkamer - 80 - Lichtgroen","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.bol_woonkamer"],"data":"{\"entity_id\":\"light.bol_woonkamer\",\"brightness\":\"80\",\"rgb_color\":[182, 217, 255]}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":937,"y":954,"wires":[[]]},{"id":"3f2675ac.61446a","type":"comment","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Voorbeeld","info":"","x":937,"y":954,"wires":[]},{"id":"ebfa90e7.59d2d8","type":"link out","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"","links":["d9e3bc7d.88258"],"x":440,"y":1303,"wires":[]},{"id":"935a99b9.140318","type":"comment","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"To NextionKap dim 1%","info":"","x":655,"y":1303,"wires":[]},{"id":"817c0f7d.7fa6a","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp Woonkamer Bol-Spot Staand Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.wallswitch02_switch"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":577,"y":1014,"wires":[["e99518ea.60b82"]]},{"id":"f60634a8.09d21","type":"link in","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"","links":["5feb5862.6190a","d3555d03.4f6d88"],"x":299,"y":827,"wires":[["817c0f7d.7fa6a","b0238c47.6446c8","80d5e65a.87c548","e6620353.63267","10cc4a239fd6de11","844e62f12948d401"]]},{"id":"3a9ed548.21f602","type":"inject","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"preCAS","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":141,"y":827,"wires":[["d3555d03.4f6d88"]]},{"id":"d3555d03.4f6d88","type":"link out","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"","links":["2fcc7466.b4484c","f60634a8.09d21"],"x":242,"y":827,"wires":[]},{"id":"56398df5.04c4cc","type":"link in","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"","links":["c1b64cc7.10cea","c1cc55e0.18e3e8"],"x":297,"y":1181,"wires":[["be5705c8.156e3","93b356e1.bf8b48","aaea4172.b7083","817c0f7d.7fa6a","ebfa90e7.59d2d8","b0238c47.6446c8","80d5e65a.87c548","3ce2ab917f8e3f2a","29f48820f1c9805c","449d2fc0.57581"]]},{"id":"8ceface8.f1df3","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp Whiskey Nis","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.lamp_woonkamer_2_spot_whisky_nis_731"],"data":"{\"brightness\":\"127\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1567,"y":940,"wires":[[]]},{"id":"52c4fa0d.5a2254","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp Zithoek 2-Spots","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.multilevel_power_switch_level"],"data":"{\"brightness\":\"10\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1797,"y":940,"wires":[[]]},{"id":"80d5e65a.87c548","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Schakelaar Kantoor: 3x rolluik dicht","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.relay_2_relay_3"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":557,"y":900,"wires":[["3cbad8e1.fbf658"]]},{"id":"be5705c8.156e3","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Tuin Voor Poort Dicht","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"cover","service":"close_cover","areaId":[],"deviceId":[],"entityId":["cover.tuin_voor_poort_cover"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":522,"y":1345,"wires":[["361433da.39584c"]]},{"id":"aaea4172.b7083","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Rolluik Woonkamer Groot Voor 60%","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.rolluik_woonkamer_groot_voor_143"],"data":"{\"entity_id\":\"cover.rolluik_woonkamer_groot_voor_143\",\"position\":\"60\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":571,"y":1251,"wires":[["facb8043.8c3f48"]]},{"id":"facb8043.8c3f48","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Rolluik Keuken","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"cover","service":"close_cover","areaId":[],"deviceId":[],"entityId":["cover.rolluik_keuken_185"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":831,"y":1251,"wires":[["3c93bb44.89aca4"]]},{"id":"3c93bb44.89aca4","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Rolluik Woonkamer Achter Klein","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"cover","service":"close_cover","areaId":[],"deviceId":[],"entityId":["cover.rolluik_woonkamer_achter_klein_734"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1078,"y":1251,"wires":[["ea99117d.759f5"]]},{"id":"ea99117d.759f5","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Rolluik Badkamer","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"cover","service":"close_cover","areaId":[],"deviceId":[],"entityId":["cover.rolluik_badkamer_776"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1329,"y":1251,"wires":[["f1629fc1.5d2b18"]]},{"id":"f1629fc1.5d2b18","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Rolluik Woonkamer OSD","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"cover","service":"close_cover","areaId":[],"deviceId":[],"entityId":["cover.rolluik_woonkamer_osd_1047"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1569,"y":1251,"wires":[["d21fc9de.db2d38"]]},{"id":"d21fc9de.db2d38","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Rolluik Woonkamer Klein Voor","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"cover","service":"close_cover","areaId":[],"deviceId":[],"entityId":["cover.zmnhcd1_1476"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1849,"y":1251,"wires":[[]]},{"id":"60146cfe.b8424c","type":"inject","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"CAS","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":147,"y":1181,"wires":[["c1b64cc7.10cea"]]},{"id":"c1b64cc7.10cea","type":"link out","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"","links":["2fcc7466.b4484c","56398df5.04c4cc"],"x":240,"y":1181,"wires":[]},{"id":"e6620353.63267","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Overkapping Tafel","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.overkapping_lamp_tafel_1106"],"data":"{\"brightness\":\"100\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":507,"y":760,"wires":[["fef32967.b58a4"]]},{"id":"fef32967.b58a4","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"LED R","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.schuur_ledspots_r_919"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":687,"y":760,"wires":[[]]},{"id":"3cbad8e1.fbf658","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Rolluik Woonkamer Groot Voor 60%","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.rolluik_woonkamer_groot_voor_143"],"data":"{\"entity_id\":\"cover.rolluik_woonkamer_groot_voor_143\",\"position\":\"60\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":891,"y":900,"wires":[[]]},{"id":"5cb54289.40448c","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Kerstboom Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.wallswitch07_switch"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":693,"y":814,"wires":[["cf3b59b16fb17105"]]},{"id":"e99518ea.60b82","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Zithoekje Staand Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.wallswitch10_switch"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":877,"y":1014,"wires":[[]]},{"id":"dbaa23c6.36e59","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Kerstboom Kap Uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.wallswitch12_switch"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1607,"y":1104,"wires":[[]]},{"id":"cf3b59b16fb17105","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Kerstverlichting Overkapping Buiten aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.wallswitch03_switch"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":977,"y":814,"wires":[["fa0fe2e6f42263d6"]]},{"id":"3ce2ab917f8e3f2a","type":"link out","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"","mode":"link","links":["bd2d9e89b4ec75b0"],"x":436,"y":1206,"wires":[]},{"id":"d98ee1d074ec7e68","type":"comment","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"To Schuur Tab","info":"","x":581,"y":1206,"wires":[]},{"id":"fa0fe2e6f42263d6","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Kerstverlichting Gras Opzetboom aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.kerstboom_achtertuin_gras"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1327,"y":815,"wires":[["8f8edc62.08e4b8"]]},{"id":"876420bdca9d8e60","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Kerstverlichting Gras Opzetboom Uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.kerstboom_achtertuin_gras"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1327,"y":1104,"wires":[["dbaa23c6.36e59"]]},{"id":"10cc4a239fd6de11","type":"api-current-state","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Kerstseizoen?","server":"c6b350c5.b8b3c","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.kerst_seizoen","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"data.original_state","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":498,"y":815,"wires":[["5cb54289.40448c"],[]]},{"id":"6f380720.197a3","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp Zitkluil","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.tuin_a_lamp_zitkuil"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1367,"y":940,"wires":[[]]},{"id":"29f48820f1c9805c","type":"api-current-state","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Kerstseizoen?","server":"c6b350c5.b8b3c","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.kerst_seizoen","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"data.original_state","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":497,"y":1101,"wires":[["a4cae1bce92ffcd9"],[]]},{"id":"361433da.39584c","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Overkapping Gootsteen Uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.overkapping_lamp_goosteen_1288"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":762,"y":1345,"wires":[["294d8fe496c3ebad"]]},{"id":"294d8fe496c3ebad","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Water Kraan Tuin Voor Uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.tuin_voor_water"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1012,"y":1345,"wires":[["c40355c5.227a28"]]},{"id":"c40355c5.227a28","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Overkapping Tafel Uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.overkapping_lamp_tafel_1106"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1242,"y":1345,"wires":[["50e3c24e.779d6c"]]},{"id":"39f5b348.b857ec","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"LED R Uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.schuur_ledspots_r_919"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1602,"y":1345,"wires":[["b5907f94.072d18"]]},{"id":"50e3c24e.779d6c","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp Zitkuil Uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.tuin_a_lamp_zitkuil"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1442,"y":1345,"wires":[["39f5b348.b857ec"]]},{"id":"b5907f94.072d18","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"LED L Uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.schuur_ledspots_l_946"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1742,"y":1345,"wires":[["a8cc5043a6b7f88d"]]},{"id":"a8cc5043a6b7f88d","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Stopcontact Tuin A Container Uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.tuin_achter_stopcontact_container"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1952,"y":1345,"wires":[[]]},{"id":"449d2fc0.57581","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp op Piano aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.wallswitch01_switch"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":512,"y":1395,"wires":[["3fffb59b.560db2"]]},{"id":"3fffb59b.560db2","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp Keuken 2-spots Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.lamp_keuken_2_spots_124"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":759,"y":1397,"wires":[["e10bdedf.b8061"]]},{"id":"e10bdedf.b8061","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp Keuken 4-spots","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.lamp_keuken_4_spots_123"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1006,"y":1397,"wires":[["49b1bae6.bd7f6c"]]},{"id":"8f8edc62.08e4b8","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Kerstboom Kap Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.wallswitch12_switch"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1610.199951171875,"y":816.7000122070312,"wires":[[]]},{"id":"a4cae1bce92ffcd9","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Kerstverlichting Overkapping Buiten Uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.wallswitch03_switch"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":977,"y":1104,"wires":[["876420bdca9d8e60"]]},{"id":"49b1bae6.bd7f6c","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp hal voorkant 2-spots Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.lamp_hal_voorkant_2_spots_nis_164"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1269,"y":1397,"wires":[["e609437a.6a9bf8"]]},{"id":"e609437a.6a9bf8","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp Keuken Eettafel Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.lamp_keuken_eettafel_108"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1555,"y":1397,"wires":[["30e793a8.cd7c3c"]]},{"id":"30e793a8.cd7c3c","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Lamp Keuken 2-spots Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.lamp_keuken_2_spots_124"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1821,"y":1397,"wires":[["bb360d46a46c17fe"]]},{"id":"844e62f12948d401","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Tuin_A_Spot_1 Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.tuin_a_spot_1"],"data":"{\"brightness\":255,\"rgb_color\":[127, 255, 0]}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":520,"y":860,"wires":[["bae8d96e9b009397"]]},{"id":"bae8d96e9b009397","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Tuin_A_Spot_2 Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.tuin_a_spot_2"],"data":"{\"brightness\":255,\"rgb_color\":[255, 119, 75]}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":740,"y":860,"wires":[["edd16f99fe226cc2"]]},{"id":"edd16f99fe226cc2","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Tuin_A_Spot_3 Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.tuin_a_spot_3"],"data":"{\"brightness\":255,\"rgb_color\":[255, 191, 0]}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":960,"y":860,"wires":[["db9610e9b099bd01"]]},{"id":"db9610e9b099bd01","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Tuin_A_Spot_4 Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.tuin_a_spot_4"],"data":"{\"brightness\":255,\"rgb_color\":[0, 255, 191]}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1180,"y":860,"wires":[["57c92285378e1efc"]]},{"id":"bb360d46a46c17fe","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Tuin_A_Spots 3x & 4x uit","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.tuin_a_spot_3x","light.tuin_a_spot_4x","light.tuin_a_spot_8"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2090,"y":1397,"wires":[[]]},{"id":"453e19ba8e0146d0","type":"api-call-service","z":"6f59380a.4fad78","g":"820b331503bb5fe0","name":"Tuin_A_Spot_8 Aan","server":"c6b350c5.b8b3c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.tuin_a_spot_8"],"data":"{\"brightness\":255,\"rgb_color\":[255, 191, 0]}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2060,"y":860,"wires":[[]]},{"id":"c6b350c5.b8b3c","type":"server","name":"Home Assistant","version":5,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Another thing, not related is:
I use “scenes” form homeassitant. But they are actually empty there. I monitor them activated in node-red:
when I wanted to make s creenshot from the scene (being empty) I pressed the line and it activated the scene… very annoying :-).
There’s no option to “edit” when I click the scene node red just starts it.
Again, I never use it that way, but it remarkable.
Based on that, I would start by searching for automations that reference the media_player created by the samsung integration and any light/switch/sensor included in that scene.
Secondly, do you have any RF blasters in your house? Are any of those lights or covers in that scene an IR controlled device?
The TV is not referenced… nowhere. I never had this issue but I think it is related so some recent update (last 2-3 weeks).
No
No
Well, at this point, because your light has no context in HA (i.e. volume increased by XYZ), that means it’s not coming from HA. It’s coming externally or via Node Red because NodeRed does not supply context. Personally, I think it’s related to a flow in NodeRed. I’ve helped people work through odd things like this in the past and it’s always a rogue flow.
