Samsung Washing Machine Card
Ok yes, that’s what I could notice during my tests :sweat_smile:
Maybe adding it in the doc could help to understand :ok_hand:
Thanks for the work anyway, it seems to work well on my side
It appears you may still be using the default theme (or mushroom)
You need to change your theme (under your profile settings, your icon at bottom left of left pane) to “minimalist-desktop” which should fix the multiple outline issue on your setup and make it look as intended.
I really love the way this card looks but i don’t get the energie en remaining time working.
I do not use yaml mode for the frontend. so i have paste the template code in de raw config editor. but when i paste the code for the remaining time in my card setup i get the following error.
Configuration errors detected:
bad indentation of a mapping entry (7:61)
4 | … r: switch.wasmachine
5 | … ine_state: sensor.wasmachine_washer_machine_state
6 | … state: sensor.wasmachine_washer_job_state
7 | … l_running: "[[[ return states["sensor.wasmachine_remaining_time …
this is my card set-up:
type: custom:button-card
template: custom_card_haven_washer
variables:
  ulm_custom_card_washer_power: switch.wasmachine
  ulm_custom_card_washer_machine_state: sensor.wasmachine_washer_machine_state
  ulm_custom_card_washer_job_state: sensor.wasmachine_washer_job_state
  ulm_custom_card_washer_label_running: "[[[ return states["sensor.wasmachine_remaining_time"].state; ]]]"
How can i get this working?
Start with reading the error? But my guess is that the template is incorrect
I am struggling with the SmartThings integration for my washer - only some entities are available for some reason, and I can’t figure out why? Anyone know how I can fix it?
The state and completion time doesn’t work, so I can’t use any of the nice cards here :stuck_out_tongue_winking_eye:
These are the entities filtered for my washer, some say “This entity is no longer being provided by the smartthings integration. If the entity is no longeri n use, delete it in settings.” …
My dryer seems a little better, but some entities also are problemtatic there, but only 4: switch.torretumbler, sensor.torretumbler_energy_meter, sensor.torretumbler_energy_saved and sensor.torretumbler_power_meter are “no longer available” …
I am also having the same issue which when I add the card:
template: custom_washer_state_grid
variables:
    ulm_custom_washer_grid_machine_state: switch.washer
    ulm_custom_washer_grid_job_state: sensor.washer_job_state
    ulm_custom_washer_grid_completion_timestamp: sensor.washer_remaining_time
and on the Card Configuration screen I get the Custom element doesn’t exist: button-card error message:
I have added the ‘button_card_templates’ codes in the top of the raw editor before as described.
Any idea what is wrong? Seen a few people say they have the same problem but didn’t find a solution.
Thank you.
Did he ever reply with a solution? I have been unable to get this template to work… I get the same errors…
You did install the custom component button-card via HACS before? Also, after doing so you need to restart Home Assistant.
I got it working, install the different HACS integrations as he said.
Add the template code to your configuration for the remaining time.
Add the button card template code to the raw configuration editor of your dashboard, add it on the first row.
Add the card configuration with your specific entity names of the washer:
variables:
Does the integration actually provide anyhting useful? I have both washer and dryer and would be happy with just integrating some status notifications, but my dryer seems to just alternate between “drying” and “weightSensing”.
Smartthings is what you seek. At least, if you have a Samsung dryer / washer
Thanks for this example!
I have the washer card working but i’m stuck adding a separate dryer card.
  • I copied and added the configuration template code for the remaining time and modified it for the washer:
- sensor:
      - unique_id: dryer_completion_time
        state: >-
          {% set rem_h = (as_timestamp(states.sensor.wasdroger_dryer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-H', false) %}
          {% set rem_m = (as_timestamp(states.sensor.wasdroger_dryer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-M', false) %}
          {% if int(rem_h) > 0.9 %} {{ rem_h }} hour(s) and {{ rem_m }} minute(s)  {% else %} {{ rem_m }} minute(s) {% endif %}
  • I copied your washer template code and added it below the template code for the washer in the raw editor:
custom_dryer_state_job_state_grid_item_list:
    styles:
      card:
        - box-shadow: none
        - padding: 0px
        - border-radius: var(--border-radius)
        - pointer-events: none
        - background-color: rgba(var(--color-theme), 0.05)
        - justify-items: center
      grid:
        - grid-template-areas: '"item1 item2 item3"'
        - grid-template-columns: 1fr 1fr 1fr
        - grid-template-rows: min-content
        - column-gap: 7px
      img_cell:
  custom_dryer_state_grid_job_state_item_list_items:
    show_icon: true
    show_name: false
    tap_action:
      action: none
    styles:
      card:
        - box-shadow: none
        - padding: 0px
        - border-radius: 50%
        - place-self: center
        - height: 42px
        - width: 42px
        - pointer-events: auto
        - background-color: transparent
      grid:
        - grid-template-areas: '"i"'
      icon:
        - color: var(--color-theme)
  custom_dryer_state_grid_state_item_list:
    styles:
      card:
        - box-shadow: none
        - padding: 0px
      grid:
        - grid-template-areas: '"item1 item2"'
        - column-gap: 7px
  custom_dryer_state_grid:
    styles:
      card:
        - box-shadow: var(--box-shadow)
        - padding: 12px
      grid:
        - grid-template-areas: '"item1" "item2"'
        - grid-template-rows: min-content  min-content
        - row-gap: 12px
    custom_fields:
      item1:
        card:
          template: custom_dryer_state_grid_state_item_list
          custom_fields:
            item1:
              card:
                template:
                  - icon_info
                entity: '[[[ return variables.ulm_custom_dryer_grid_machine_state ]]]'
                icon: mdi:tumble-dryer
                tap_action:
                  action: more-info
                label: not running
                state:
                  - value: 'on'
                    label: running
                    styles:
                      icon:
                        - color: rgba(var(--color-blue), 1)
                      img_cell:
                        - background-color: rgba(var(--color-background-blue), 0.2)
            item2:
              card:
                type: conditional
                conditions:
                  - entity: >-
                    state: 'on'
                card:
                  template:
                    - icon_info
                  entity: >-
                    [[[ return
                    variables.ulm_custom_dryer_grid_completion_timestamp ]]]
                  icon: mdi:progress-clock
                  tap_action:
                    action: none
                  label: >-
                    [[[ return
                    states[variables.ulm_custom_dryer_grid_completion_timestamp].state
      item2:
        card:
          template: custom_dryer_state_job_state_grid_item_list
          custom_fields:
            item1:
              card:
                icon: mdi:scale
                template: custom_dryer_state_grid_job_state_item_list_items
                entity: '[[[ return variables.ulm_custom_dryer_grid_job_state ]]]'
                state:
                  - value: weightSensing
                    styles:
                      icon:
                        - transform: scale(1.2)
                        - color: black
                      card:
                        - background-color: grey
            item2:
              card:
                icon: mdi:hair-dryer
                state:
                  - value: drying
                    styles:
                      icon:
                        - color: black
                      card:
            item3:
              card:
                icon: mdi:snowflake
                state:
                  - value: cooling
                    styles:
                      icon:
                        - color: black
                      card:
  • I try to create a new custom button card:
variables:
ulm_custom_washer_grid_machine_state: switch.wasdroger
ulm_custom_washer_grid_job_state: sensor.wasdroger_dryer_job_state
ulm_custom_washer_grid_completion_timestamp: sensor.wasdroger_dryer_completion_time
Generates the following error:
ButtonCardJSTemplateError: TypeError: Cannot read properties of undefined (reading ‘state’) in ‘return states[variables.ulm_custom_dryer_grid_completion_timestamp].state’
I don’t understand what and where to modify.
Who can point me in the right direction?
Thanks!
Hey, you’re almost there. You forgot to change your button card’s variable names from washer to dryer:
to:
ulm_custom_dryerr_grid_machine_state: switch.wasdroger
ulm_custom_dryer_grid_job_state: sensor.wasdroger_dryer_job_state
ulm_custom_dryer_grid_completion_timestamp: sensor.wasdroger_dryer_completion_time
As your dryer template will be looking for the dryer variables.
This card is a goldmine but despite the discussion I can’t find why it’s not working for me.
I have the following error in my card:
Any idea?
Wow, i just overlooked that one. Thanks a lot!!!
They both work now. The only thing that doesn’t work like its supposed to is the completion time.
I have the same issue as @asgeirsb
It’s noted as a full date and time + 00:00 instead of just a remain time (hours:minutes)
Any ideas on that?
Thanks!
This is my approach, more minimalistic, conditional chips at the top of the view, It only appears when it is turned on showing the remaining time. Finish event is announced thru samsung tv notification and alexa.
Replying to myself: In custom button card, I changed the name of the switch and sensor with the name of my switch and sensor.
I really like this, it is all I need.
If you don’t mind, could you please share your card and what all you had to add?
It’s been 1-2 years since I tried to set it all up and I don’t remember what I already did/added.
Sure!
First create a sensor to format the remaining time:
  - sensor:
      - name: "Lavadora tiempo"
        state: >
            {% set ct = states('sensor.lavadora_washer_completion_time') | as_datetime %}
            {{ '00:00' if now() > ct else (ct - now()).total_seconds() | timestamp_custom('%H:%M', false) }}
Then add the mushroom chip (install thru HACS frontend)
type: custom:mushroom-chips-card
chips:
  - type: conditional
    conditions:
      - entity: switch.lavadora
        state: 'on'
    chip:
      type: entity
      entity: sensor.lavadora_tiempo
      icon: mdi:washing-machine
      icon_color: cyan
“switch.lavadora” is the only entity that have a switch in the washing machine device, to determinate if is on or off.
Similar to what @Lainol did with creating a new sensor by formatting the time, create template sensors:
template:
  - sensor:
    - name: 'Washer Remaining Time'
      state: >-
        {% set rem_h = (as_timestamp(states.sensor.washer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-H', false) %}
        {% set rem_m = (as_timestamp(states.sensor.washer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-M', false) %}
        {% if int(rem_h) > 0.9 %} {{ rem_h }}hr {{ rem_m }}m  {% else %} {{ rem_m }}m {% endif %}
    - name: 'Dryer Remaining Time'
      state: >-
        {% set rem_h = (as_timestamp(states.sensor.dryer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-H', false) %}
        {% set rem_m = (as_timestamp(states.sensor.dryer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-M', false) %}
And use those instead for your completion time
