I’m getting this error, any idea what might be happening?
ButtonCardJSTemplateError: TypeError: Cannot read properties of undefined (reading 'state') in 'return states[variables.ulm_custom_washer_grid_completion_timestamp].state'
tap_action:
action: none
type: custom:button-card
group_expand: false
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
color_type: icon
show_name: true
show_state: false
show_icon: true
show_units: true
show_label: false
show_entity_picture: false
show_live_stream: false
card_size: 3
styles:
card:
- border-radius: var(--border-radius)
- box-shadow: var(--box-shadow)
- padding: 12px
grid:
- grid-template-areas: '"item1" "item2"'
- grid-template-columns: 1fr
- grid-template-rows: min-content min-content
- row-gap: 12px
custom_fields:
item1:
card:
template: custom_washer_state_grid_state_item_list
custom_fields:
item1:
card:
template:
- icon_info
entity: '[[[ return variables.ulm_custom_washer_grid_machine_state ]]]'
icon: mdi:washing-machine
tap_action:
action: more-info
label: not running
state:
- value: 'on'
label: running
styles:
icon:
- color: rgba(var(--color-blue), 1)
img_cell:
- background-color: rgba(var(--color-background-blue), 0.2)
item2:
card:
type: conditional
conditions:
- entity: '[[[ return variables.ulm_custom_washer_grid_machine_state ]]]'
state: 'on'
card:
template:
- icon_info
entity: >-
[[[ return variables.ulm_custom_washer_grid_completion_timestamp
icon: mdi:progress-clock
tap_action:
action: none
label: >-
[[[ return
item2:
card:
template: custom_washer_state_job_state_grid_item_list
custom_fields:
item1:
card:
icon: mdi:scale
template: custom_washer_state_grid_job_state_item_list_items
entity: '[[[ return variables.ulm_custom_washer_grid_job_state ]]]'
state:
- value: weightSensing
styles:
icon:
- transform: scale(1.2)
- color: black
card:
- background-color: grey
item2:
card:
icon: mdi:waves
state:
- value: wash
styles:
icon:
- color: black
card:
item3:
card:
icon: mdi:water
state:
- value: rinse
styles:
icon:
- color: black
card:
item4:
card:
icon: mdi:fan
state:
- value: spin
styles:
icon:
- color: black
card:
item5:
card:
icon: mdi:tumble-dryer
state:
- value: drying
styles:
icon:
- color: black
card:
variables:
ulm_custom_washer_grid_machine_state: switch.laundry_room_washer
ulm_custom_washer_grid_job_state: sensor.laundry_room_washer_washer_job_state
ulm_custom_washer_grid_completion_timestamp: sensor.washer_remaining_time
state: []
lock:
enabled: false
duration: 5
unlock: tap
Replying to myself. I redid every step in this thread and got it working flawlessly.
I’ve noticed that with presented template after end of washing / drying cycle it’s still counting:
{% set rem_h = (as_timestamp(states.sensor.washer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-H', false) %}
{% set rem_m = (as_timestamp(states.sensor.washer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-M', false) %}
{% if int(rem_h) > 0.9 %} {{ rem_h }} hour(s) and {{ rem_m }} minute(s) {% else %} {{ rem_m }} minute(s) {% endif %}
I’ve changed it to assure that completion_time is in the future (and therefore avoiding every-minute-entry in the Logbook with irrelevant data):
{% set completion_time = states.sensor.washer_completion_time.state %}
{% set completion_timestamp = as_timestamp(completion_time) %}
{% set current_timestamp = as_timestamp(now()) %}
{% if completion_timestamp > current_timestamp %}
{% set rem_h = ((completion_timestamp - current_timestamp) | timestamp_custom('%-H', false)) | int %}
{% set rem_m = ((completion_timestamp - current_timestamp) | timestamp_custom('%-M', false)) | int %}
{% if rem_h > 0.9 %}
{% else %}
{% endif %}
{% else %}
Off
{% endif %}
Gathaeryx
(Gathaeryx)
April 17, 2024, 1:34pm
45
Does anyone know how to remove the borders that appear when creating this card? I updated HA docker from version 2023.10.3 to 2024.4.3 today, but for some reason this card now has borders around every button.
Check Theme Settings => I’ve experienced similar issues which could be fixed by choosing the right one.
I’ve got that set (and still have, just checked!) but after one of the recent updates it brokes. No icon visible What could that be?
Finally got it running. Had to check all the sensors 3 times to solve every issue.
The template sensor shows up as: sensor.remaining_time for no known reason, but works fine otherwise.
My washer entitiies also start with washer_washer_ instead of just washer_
Fixing it made it work.
But does anyone know how to get round corners?
@dennisschmitz55m is there any chance you could paste a copy of the latest working version, seems to be lots of changes and hard to tell what is the actual working code. TIA.
I used the template in the first post on configuration.yaml
Just had to adjust the states.sensor values to washer_washer_completion_time.state instead of just washer_completion_time.state
#washer sensor
template:
- sensor:
- unique_id: washer_remaining_time
state: >-
{% set rem_h = (as_timestamp(states.sensor.washer_washer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-H', false) %}
{% set rem_m = (as_timestamp(states.sensor.washer_washer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-M', false) %}
The resulting sensor has the name: sensor.remaining_time instead if sensor.washer_remaining_time and I have no clue why…,
Anyway, just had to adjust that inside the button card itself which here looks like this:
variables:
ulm_custom_washer_grid_machine_state: switch.washer
ulm_custom_washer_grid_job_state: sensor.washer_washer_job_state
ulm_custom_washer_grid_completion_timestamp: sensor.remaining_time
The template for the raw configuration looks like this here with the only adjustment I made was for rounded corners
button_card_templates:
icon_info:
color: var(--color-theme)
show_icon: true
show_name: true
show_label: true
custom_fields:
notification: |
if (entity.state =='unavailable'){
return `<ha-icon icon="mdi:exclamation" style="width: 12px; height: 12px; color: var(--primary-background-color);"></ha-icon>`
state:
- styles:
custom_fields:
notification:
- border-radius: 50%
- position: absolute
- left: 24px
- top: '-2px'
- height: 16px
- width: 16px
- border: 2px solid var(--card-background-color)
- font-size: 12px
- line-height: 14px
- background-color: |
return "rgba(var(--color-red),1)";
value: unavailable
styles:
card:
- border-radius: 21px 8px 8px 21px
- box-shadow: none
- padding: 0px
grid:
- grid-template-areas: '"i n" "i l"'
- grid-template-columns: min-content auto
icon:
- color: rgba(var(--color-theme),0.2)
img_cell:
- background-color: rgba(var(--color-theme),0.05)
- place-self: center
- width: 42px
- height: 42px
name:
- align-self: end
- justify-self: start
- font-weight: bold
- font-size: 14px
- margin-left: 12px
label:
- align-self: start
- font-weight: bolder
- font-size: 12px
- filter: opacity(40%)
- margin-left: 12px
state:
- align-self: start
- font-size: 12px
- margin-left: 12px
custom_washer_state_job_state_grid_item_list:
styles:
card:
- box-shadow: none
- padding: 0px
- border-radius: 10px
- pointer-events: none
- background-color: rgba(var(--color-theme), 0.05)
- justify-items: center
grid:
- grid-template-areas: '"item1 item2 item3 item4"'
- grid-template-columns: 1fr 1fr 1fr 1fr
- column-gap: 7px
img_cell:
custom_washer_state_grid_job_state_item_list_items:
show_icon: true
show_name: false
tap_action:
action: none
styles:
card:
- box-shadow: none
- padding: 0px
- height: 42px
- width: 42px
- pointer-events: auto
- background-color: transparent
grid:
- grid-template-areas: '"i"'
icon:
- color: var(--color-theme)
custom_washer_state_grid_state_item_list:
styles:
card:
- box-shadow: none
- padding: 0px
grid:
- grid-template-areas: '"item1 item2"'
- column-gap: 7px
custom_washer_state_grid:
styles:
card:
- padding: 12px
grid:
- row-gap: 12px
custom_fields:
item1:
card:
custom_fields:
item1:
card:
template:
- icon_info
tap_action:
action: more-info
label: not running
state:
- value: 'on'
label: running
styles:
icon:
img_cell:
item2:
card:
type: conditional
conditions:
- entity: >-
state: 'on'
card:
template:
- icon_info
entity: >-
[[[ return
variables.ulm_custom_washer_grid_completion_timestamp ]]]
tap_action:
action: none
label: >-
[[[ return
item2:
card:
custom_fields:
item1:
card:
icon: mdi:scale
state:
styles:
icon:
- color: black
card:
item2:
card:
icon: mdi:waves
state:
- value: wash
styles:
icon:
- color: black
card:
item3:
card:
icon: mdi:water
state:
- value: rinse
styles:
icon:
- color: black
card:
item4:
card:
icon: mdi:fan
state:
- value: spin
styles:
icon:
- color: black
card:
Goofi
(Goofus27)
May 11, 2024, 9:31am
52
Hey hello
can you please advice me what i need to change.
when i used your setting i see this
see remaining time. it shows 2024 05 11 T09:29:22+00:00
variables:
ulm_custom_washer_grid_machine_state: switch.wasmachinenl_switch
ulm_custom_washer_grid_job_state: sensor.wasmachinenl_washer_job_state
ulm_custom_washer_grid_completion_timestamp: sensor.wasmachinenl_washer_completion_time
It looks like something is wrong with the template sensor in your configuration.yaml and outputting the wrong numbers.
Goofi
(Goofus27)
May 27, 2024, 12:23am
54
Can you please also tell me how to make it bigger the icon and time.
thanks in advance.
Lainol
July 7, 2024, 4:34pm
55
Chips Card
Sections are split:
Main Icon Styling You can style the main icon of each chip type like this:
Change the icon type/mdi.
[image]
The weather chip icon cannot be modified as it is not a normal HA icon.
Note that when you have a conditional chip (like the first chip in this config is) with another chip inside of it you need to go 1 layer deeper.
card_mod:
style:
mushroom-conditional-chip:nth-child(1):
mushroom-template-chip$: |
ha-state-icon {
--card-…
Here you go! Sorry for the delay.
i tried the whole stuff but my button card is just empty. any changes which are know to be done because auf new HA version(s)?
Hi All !
Same here , i have done every steps , here is my card :
variables:
ulm_custom_washer_grid_machine_state: sensor.lave_linge_washer_machine_state
ulm_custom_washer_grid_job_state: sensor.lave_linge_washer_job_state
But just nothing appears , if anyone can help please ?
Edit: i have now added the last variables and it shows this :
variables:
ulm_custom_washer_grid_completion_timestamp: sensor.lave_linge_washer_completion_time
So it seems to work but i have a problem with the “completion time” sensor, but when i go to completion time sensor in DEV i can see this :
Is there really no simple HACS download for a washing machine card template yet?
Is there one I can just copy code for at least that is currently working?
I have a Samsung Series 7 Washer Dryer.
Sashik259
(Sashik259)
August 5, 2025, 4:27pm
59
Hello!
Can anyone help?
washer_machine_state doesn’t show real machine status.
It shows not running while it is running. And it doesn’t show remaining time
TEMPLATE:
icon_info:
show_icon: true
show_name: true
show_label: true
custom_fields:
notification: |
state:
- styles:
custom_fields:
notification:
- left: 24px
- top: '-2px'
- height: 16px
- width: 16px
- font-size: 12px
- line-height: 14px
value: unavailable
styles:
card:
- box-shadow: none
- padding: 0px
grid:
icon:
img_cell:
- width: 42px
- height: 42px
name:
- align-self: end
- font-weight: bold
- font-size: 14px
- margin-left: 12px
label:
- align-self: start
- font-size: 12px
- margin-left: 12px
state:
- align-self: start
- font-size: 12px
- margin-left: 12px
styles:
card:
- box-shadow: none
- padding: 0px
grid:
- column-gap: 7px
img_cell:
show_icon: true
show_name: false
tap_action:
action: none
styles:
card:
- box-shadow: none
- padding: 0px
- height: 42px
- width: 42px
grid:
icon:
styles:
card:
- box-shadow: none
- padding: 0px
grid:
- column-gap: 7px
styles:
card:
- padding: 12px
grid:
- row-gap: 12px
custom_fields:
item1:
card:
custom_fields:
item1:
card:
template:
- icon_info
tap_action:
action: more-info
label: not running
state:
- value: 'on'
label: running
styles:
icon:
img_cell:
item2:
card:
type: conditional
conditions:
- entity: >-
state: 'on'
card:
template:
- icon_info
entity: >-
[[[ return
tap_action:
action: none
label: >-
[[[ return
item2:
card:
custom_fields:
item1:
card:
icon: mdi:scale
state:
styles:
icon:
- color: black
card:
item2:
card:
icon: mdi:waves
state:
- value: wash
styles:
icon:
- color: black
card:
item3:
card:
icon: mdi:water
state:
- value: rinse
styles:
icon:
- color: black
card:
item4:
card:
icon: mdi:fan
state:
- value: spin
styles:
icon:
- color: black
card:
CARD
variables:
ulm_custom_washer_grid_machine_state: sensor.washer_machine_state
ulm_custom_washer_grid_job_state: sensor.washer_job_state
Hi!
Maybe is a little to late but for anyone who had the same problem i made a little modification to make it work, or at least for me it worked!
TEMPLATE:
icon_info:
show_icon: true
show_name: true
show_label: true
custom_fields:
notification: |
state:
- styles:
custom_fields:
notification:
- left: 24px
- top: "-2px"
- height: 16px
- width: 16px
- font-size: 12px
- line-height: 14px
value: unavailable
styles:
card:
- border-radius: 18px 8px 8px 18px
- box-shadow: none
- padding: 0px
grid:
- grid-template-areas: "\"i n\" \"i l\""
icon:
img_cell:
- width: 42px
- height: 42px
name:
- align-self: end
- font-weight: bold
- font-size: 14px
- margin-left: 12px
label:
- align-self: start
- font-size: 12px
- margin-left: 12px
state:
- align-self: start
- font-size: 12px
- margin-left: 12px
styles:
card:
- box-shadow: none
- padding: 0px
grid:
- grid-template-areas: "\"item1 item2 item3 item4\""
- column-gap: 7px
img_cell:
show_icon: true
show_name: false
tap_action:
action: none
styles:
card:
- box-shadow: none
- padding: 0px
- height: 42px
- width: 42px
grid:
- grid-template-areas: "\"i\""
icon:
styles:
card:
- box-shadow: none
- padding: 0px
grid:
- grid-template-areas: "\"item1 item2\""
- column-gap: 7px
styles:
card:
- padding: 12px
grid:
- grid-template-areas: "\"item1\" \"item2\""
- row-gap: 12px
custom_fields:
item1:
card:
custom_fields:
item1:
card:
template:
- icon_info
entity: "[[[ return variables.ulm_custom_washer_grid_machine_state ]]]"
tap_action:
action: more-info
label: Unavailable
state:
- value: stop
label: Stopped
styles:
icon:
img_cell:
- value: run
label: Running
styles:
icon:
img_cell:
- value: pause
label: Paused
styles:
icon:
img_cell:
item2:
card:
type: conditional
conditions:
- entity: >-
state: run
card:
template:
- icon_info
entity: >-
[[[ return
tap_action:
action: none
label: >-
[[[ return
item2:
card:
custom_fields:
item1:
card:
icon: mdi:scale
entity: "[[[ return variables.ulm_custom_washer_grid_job_state ]]]"
state:
styles:
icon:
- color: black
card:
item2:
card:
icon: mdi:waves
state:
- value: wash
styles:
icon:
- color: black
card:
item3:
card:
icon: mdi:water
state:
- value: rinse
styles:
icon:
- color: black
card:
item4:
card:
icon: mdi:fan
state:
- value: spin
styles:
icon:
- color: black
card:
