I have a problem with my “trustet devices” from Samsung TV.
When i connect my HomeAssistant with the Television, i am able to control the TV as it has to be… i am also able to switch the TV off - but not able to switch it on.
When i switch the TV on with the remote control, i have to “pair” the HomeAssistant again.
The TV was found automatically and i used the Lovelace card which was integrated automatically. do i have to change anything?
all works, unfortunally not to turn on.
automation:
- alias: "Turn On Living Room TV with WakeOnLan"
- platform: samsungtv.turn_on
entity_id: media_player.samsung_smart_tv
- service: wake_on_lan.send_magic_packet
mac: E0:9D:13:XX:XX:XX
this i added to my configuration.yaml
but get a error message
Die Automatisierung „Turn On Living Room TV with WakeOnLan“ („automation.turn_on_living_room_tv_with_wakeonlan“) hat eine Aktion, die einen unbekannten Dienst aufruft: „wake_on_lan.send_magic_packet“.
Dieser Fehler verhindert, dass die Automatisierung ordnungsgemäß ausgeführt wird. Vielleicht ist dieser Dienst nicht mehr verfügbar oder vielleicht hat ein Tippfehler ihn verursacht.
You are connected via Wifi right? Not all models support WoL via Wifi and it needs to be enabled in the TV menu.
Also using the media turn on service might work, but again that depends on the model and if its stays active when turned “off”.
