Automation to remotely snooze and turn off alarms with a button or other state trigger. You can use any entity and state to trigger these actions, not just buttons. For instance you can use a bed pressure sensor to automatically turn off your alarm when you get out of bed or your phone’s battery status changing to discharging when you pull it off the charger to snooze it. Get creative! Note that this blueprint is set up to update the alarm status of the first 10 alarm IDs (0-9). If you have more alarms on your Doppler, you will need to modify the blueprint. Be aware this blueprint sends the snooze and alarm off commands to all alarms with IDs 0-9 and there may be unintended side effects.
blueprint:
name: Sandman Doppler Remote Snooze and Alarm Off
description: Automation to remotely snooze and turn off alarms with a button or other state trigger. You can use any entity and state to trigger these actions, not just buttons. For instance you can use a bed pressure sensor to automatically turn off your alarm when you get out of bed or your phone's battery status changing to discharging when you pull it off the charger to snooze it. Get creative! Note that this blueprint is set up to update the alarm status of the first 10 alarm IDs (0-9). If you have more alarms on your Doppler, you will need to modify the blueprint. Be aware this blueprint sends the snooze and alarm off commands to all alarms with IDs 0-9 and there may be unintended side effects.
domain: automation
input:
alarm_entity:
description: Any entity associated with your Doppler
selector:
entity:
integration: sandman_doppler
remote_snooze:
name: Remote Snooze Entity
description: Button or other entity you want to remotely snooze your alarms with
selector:
entity:
remote_snooze_state:
name: Remote Snooze Entity State
description: State of the button or other entity you want to trigger the remote snooze
selector:
text:
remote_alarm_off:
name: Remote Alarm Off Entity
description: Button or other entity you want to remotely turn off your alarms with
selector:
entity:
remote_alarm_off_state:
name: Remote Alarm Off Button State
description: State of the button or other entity you want to trigger the remote alarm off
selector:
text:
mode: single
- platform: state
entity_id: !input remote_snooze
to: !input remote_snooze_state
alias: Remote Snooze
- platform: state
entity_id: !input remote_alarm_off
to: !input remote_alarm_off_state
id: Remote Alarm Off
alias: Remote Alarm Off
- choose:
- conditions:
condition: trigger
sequence:
parallel:
- service: sandman_doppler.update_alarm
status: snoozed
entity_id: !input alarm_entity
status: snoozed
status: snoozed
status: snoozed
status: snoozed
status: snoozed
status: snoozed
status: snoozed
status: snoozed
status: snoozed
- conditions:
- condition: trigger
sequence:
parallel:
status: unarmed
status: unarmed
status: unarmed
status: unarmed
status: unarmed
status: unarmed
status: unarmed
status: unarmed
status: unarmed
status: unarmed
