Update:
Managed to get output commands working ok, but values are not refreshing. See current code:
Saswell platform that offers a Saswell climate device.
For more details about this platform, please refer to the documentation
https://home-assistant.io/components/climate/saswell
import asyncio
import logging
from datetime import timedelta
import time
import voluptuous as vol
from homeassistant.components.climate.const import (
HVAC_MODE_HEAT,
HVAC_MODE_OFF,
PRESET_AWAY,
PRESET_HOME,
SUPPORT_TARGET_TEMPERATURE,
SUPPORT_PRESET_MODE
from homeassistant.components.sensor import PLATFORM_SCHEMA
from homeassistant.const import (
CONF_NAME,
CONF_USERNAME,
CONF_PASSWORD,
CONF_SCAN_INTERVAL,
TEMP_CELSIUS,
ATTR_TEMPERATURE
from homeassistant.helpers.event import async_track_time_interval
import homeassistant.helpers.config_validation as cv
try:
from homeassistant.components.climate import PLATFORM_SCHEMA, ClimateEntity
except ImportError:
from homeassistant.components.climate import (
PLATFORM_SCHEMA,
ClimateDevice as ClimateEntity,
_LOGGER = logging.getLogger(__name__)
TOKEN_FILE = ".saswell.token."
USER_AGENT = "Thermostat/3.1.0 (iPhone; iOS 11.3; Scale/3.00)"
AUTH_URL = "http://api.scinan.com/oauth2/authorize?client_id=100000" \
"&passwd=%s&redirect_uri=http%%3A//localhost.com%%3A8080" \
"/testCallBack.action&response_type=token&userId=%s"
LIST_URL = "http://api.scinan.com/v1.0/devices/list?format=json"
CTRL_URL = "http://api.scinan.com/v1.0/sensors/control?" \
"control_data=%%7B%%22value%%22%%3A%%22%s%%22%%7D&device_id=%s" \
"&format=json&sensor_id=%s&sensor_type=1"
CONF_TEMPERATURE = 'temperature'
CONF_TARGET_TEMPERATURE = 'target_temperature'
CONF_OPERATION = 'operation'
CONF_AWAY = 'away'
CONF_IS_ON = 'is_on'
CONF_OPERATION_LIST = 'hvac_modes'
CONF_FAN_LIST = 'fan_list'
CONF_SWING_LIST = 'swing_list'
DEFAULT_NAME = 'saswell'
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Required(CONF_USERNAME): cv.string,
vol.Required(CONF_PASSWORD): cv.string,
vol.Optional(CONF_SCAN_INTERVAL, default=timedelta(seconds=300)): (
vol.All(cv.time_period, cv.positive_timedelta)),
async def async_setup_platform(hass, config, async_add_devices,
discovery_info=None):
"""Set up the Saswell climate devices."""
name = config.get(CONF_NAME)
username = config.get(CONF_USERNAME)
password = config.get(CONF_PASSWORD)
scan_interval = config.get(CONF_SCAN_INTERVAL)
saswell = SaswellData(hass, username, password)
await saswell.update_data()
if not saswell.devs:
_LOGGER.error("No sensors added: %s.", name)
return None
devices = []
for index in range(len(saswell.devs)):
devices.append(SaswellClimate(saswell, name, index))
async_add_devices(devices)
saswell.devices = devices
async_track_time_interval(hass, saswell.async_update, scan_interval)
class SaswellClimate(ClimateEntity):
"""Representation of a Saswell climate device."""
def __init__(self, saswell, name, index):
"""Initialize the climate device."""
name += "_"
name += saswell.devs[index]['id']
self._name = name
self._index = index
self._saswell = saswell
@property
def name(self):
"""Return the name of the climate device."""
return self._name
@property
def available(self):
"""Return if the sensor data are available."""
return self.get_value('online')
@property
def supported_features(self):
"""Return the list of supported features."""
return SUPPORT_TARGET_TEMPERATURE | SUPPORT_PRESET_MODE
@property
def temperature_unit(self):
"""Return the unit of measurement."""
return TEMP_CELSIUS
@property
def target_temperature_step(self):
"""Return the supported step of target temperature."""
return 0.5
@property
def current_temperature(self):
"""Return the current temperature."""
return self.get_value(CONF_TEMPERATURE)
@property
def target_temperature(self):
"""Return the temperature we try to reach."""
return self.get_value(CONF_TARGET_TEMPERATURE)
@property
def hvac_mode(self):
"""Return current operation ie. heat, cool, idle."""
return HVAC_MODE_HEAT if self.is_on else HVAC_MODE_OFF
@property
def hvac_modes(self):
"""Return the list of available operation modes."""
return [HVAC_MODE_HEAT, HVAC_MODE_OFF]
@property
def is_away_mode_on(self):
"""Return if away mode is on."""
return self.get_value(CONF_AWAY)
@property
def is_on(self):
"""Return true if the device is on."""
return self.get_value(CONF_IS_ON)
@property
def preset_modes(self):
"""Return the list of available preset modes."""
return [PRESET_AWAY, PRESET_HOME]
@property
def preset_mode(self):
"""Return the current preset mode."""
return PRESET_AWAY if self.is_away_mode_on else PRESET_HOME
@property
def should_poll(self): # pylint: disable=no-self-use
"""No polling needed."""
return False
async def async_set_temperature(self, **kwargs):
"""Set new target temperatures."""
temperature = kwargs.get(ATTR_TEMPERATURE)
if temperature is not None:
await self.set_value(CONF_TARGET_TEMPERATURE, temperature)
async def async_set_hvac_mode(self, operation_mode):
"""Set new target hvac mode."""
if operation_mode == HVAC_MODE_HEAT:
await self.set_value(CONF_IS_ON, False)
else:
await self.set_value(CONF_IS_ON, True)
async def async_set_preset_mode(self, preset_mode):
if preset_mode == PRESET_AWAY:
await self.set_value(CONF_AWAY, True)
else:
await self.set_value(CONF_AWAY, False)
async def async_turn_on(self):
"""Turn on."""
async def async_turn_off(self):
"""Turn off."""
def get_value(self, prop):
"""Get property value"""
devs = self._saswell.devs
if devs and self._index < len(devs):
return devs[self._index][prop]
return None
async def set_value(self, prop, value):
"""Set property value"""
if await self._saswell.control(self._index, prop, value):
self.async_schedule_update_ha_state()
class SaswellData():
"""Class for handling the data retrieval."""
def __init__(self, hass, username, password):
"""Initialize the data object."""
self._hass = hass
self._username = username.replace('@', '%40')
self._password = password
self._token_path = hass.config.path(TOKEN_FILE + username)
self.devs = None
try:
with open(self._token_path) as file:
self._token = file.read()
_LOGGER.debug("Load token: %s", self._token_path)
except BaseException:
self._token = None
async def async_update(self, time):
"""Update online data and update ha state."""
old_devs = self.devs
await self.update_data()
tasks = []
index = 0
for device in self.devices:
if not old_devs or not self.devs \
or old_devs[index] != self.devs[index]:
_LOGGER.info('%s: => %s', device.name, device.state)
tasks.append(device.async_update_ha_state())
if tasks:
await asyncio.wait(tasks, loop=self._hass.loop)
async def update_data(self):
"""Update online data."""
try:
json = await self.request(LIST_URL)
if ('error' in json) and (json['error'] != '0'):
_LOGGER.debug("Reset token: error=%s", json['error'])
self._token = None
devs = []
for dev in json:
status = dev['status'].split(',')
devs.append({'is_on': status[1] == '1',
'away': status[5] == '1', #8?
'temperature': float(status[2]),
'target_temperature': float(status[3]),
'online': dev['online'] == '1',
'id': dev['id']})
self.devs = devs
_LOGGER.info("List device: devs=%s", self.devs)
import traceback
_LOGGER.error('Exception: %s', traceback.format_exc())
async def control(self, index, prop, value):
"""Control device via server."""
try:
if prop == 'is_on':
sensor_id = '01'
data = '1' if value else '0'
elif prop == 'target_temperature':
sensor_id = '02'
data = value
elif prop == 'away':
sensor_id = '03'
else:
return False
device_id = self.devs[index]['id']
json = await self.request(CTRL_URL % (data, device_id, sensor_id))
_LOGGER.debug("Control device: prop=%s, json=%s", prop, json)
if json['result']:
self.devs[index][prop] = value
return True
return False
import traceback
return False
async def request(self, url):
"""Request from server."""
session = self._hass.helpers.aiohttp_client.async_get_clientsession()
if self._token is None:
headers = {'User-Agent': USER_AGENT}
url = AUTH_URL % (self._password, self._username)
async with session.get(url, headers=headers) as response:
text = await response.text()
_LOGGER.info("Get token: %s", text)
start = text.find('token:')
if start == -1 :
return None
start += 6
end = text.find('\n', start) - 1
self._token = text[start:end]
with open(self._token_path, 'w') as file:
file.write(self._token)
url += "×tamp=%s&token=%s" % \
(time.strftime('%Y-%m-%d%%20%H%%3A%M%%3A%S'), self._token)
_LOGGER.debug("URL: %s", url)
return await response.json(content_type=None)
I’ve got a new error being thrown out:
Error doing job: Task exception was never retrieved
File "/config/custom_components/saswell/climate.py", line 258, in async_update
TypeError: wait() got an unexpected keyword argument 'loop'
