Saswell sea802
I have bought a trv
saswell sea802 and added it to conbeeII, it is not visible in the webinterface but is visible in Hass so I have a climate device. Can set temp, so far so good. But can I set default eco temp. in home assistant? If not I could pair using Zigbee2MQTT?
I run the SEA802 with Z2M. It’s not possible to set the eco temp.
That’s no good news. Well Setting it in heat and none would be the way.
