I’m using the Satel Intergra integration and have noticed some “wierd” behaviour in that armed actions are being triggered while someone enters the building.
I have the following template for the binary sensor so i can expose it to KNX:
- name: "Blok Test"
state: >-
{% if states('alarm_control_panel.test') == 'armed_away' %}
{{ 1 }}
{% elif states('alarm_control_panel.test') == 'disarmed' %}
{{ 0 }}
{% endif %}
Since i know the alarm has multiple statuses i just check for those 2.
Now the weirdness, when i arm the system it will just react to the armed_away
and i get a 1
from the binary sensor i exposed on the bus:
entity_id: binary_sensor.blok_test
address: "0/0/2"
So far so good, but then when i trigger the entry delay (by opening a door and entering the building) the following happens to the status:
- Pending (entry time started, system waiting for input)
- Disarmed
- Armed Away
- Disarmed
So the template does what it has todo, but that results in weird behaviour in the KNX with the off-on-off.
Note that this only happens when i trigger the delay time and not if i arm/disarm the alarm directly.
I can create a workaround by adding a delay to the disarmed since the follow instantly, but not sure how in the template… something like only trigger if status is x for y seconds?
