Is there any option to create a working button in dashboard to change alarm state? (armed, disarmed, away). Well, alarm panel work properly. Button that i have created with call event alarm_disarm for example, doesnt make any errors but also it simply doesnt work, doesnt give any signals.
Do u have any ideas for that?
DId you add the entity_id
to the service call on the button? You need to do this manually in the Code Editor for the Card.
Yes.
The solution was to add code: 12345 in card configuration. Its necessary
Hello
Can you post your config please. I’m having the same demand.
