Hello everyone,
I read the “how to help us to help you” but it’s my first new topic and I apologize in advance for some random mistake formulating my question.
This is my actual configuration:
- Home Assistant Core 2022.10.3
- Home Assistant Supervisor 2022.10.0
- Home Assistant OS 9.2
- Frontend 20221010.0 - latest
I tried to connect to my Satel Integra System with the integration HA but I am not able to establish the connection. Instead with de DLOADX software everything works fine. In the config.yaml file I only add the IP and the port (the same that I config in the DLOADX software for the Satel Server TCP-IP connection).
I check the “Integration” box in the configuration of my ETHM-1 Plus v. 2.04 and uncheck the “encryption integration”.
Don’t know what else I can do. Any advice?
Thank You in advance
Regards
