Satel integra integration not working
I am a new home assistant user. Trying to get everything up and running.
Am running hassos on a Intel NUC.
Tried to setup the Satel integra installation by adding yaml configuration to the configuration.yml.
satel_integra:
  host: 192.168.1.170
When I restart the server after config edit I get the following error in the logs:
“Setup failed for satel_integra: Integration failed to initialize”
Not sure what I am missing or how I can further debug this issue.
Any pointers?
Hi ,
what firmware version s your ethm + running on
maybe also just add the port for good measure
and as stated in the integration page add the zones as well since the integration won’t be able to scan for zones . ¨
I am currently running ETHM+ wit FW 2.7 an I’m having a Flaky connection, meaning sometimes it connects and sometimes it doesn’t (at boot)
But then once HA is up i lose the connection and it won’t reconnect
nevermind i fixed mine by useing the right port/ip config
Hi, i have the same error message:
Have you any suggestion? How can i check if the port is not the standard port?
Thanks in advance.
