Satel Integra... not able to integrate
Hi all,
I’m trying for weeks to get the Satel Integra integrated into HA. Until now, without success.
I have added the integration (see below) to my configuration.yaml (zones I have copied from the satel integra app…). I tried several ports: 7090, 7091, 7094, 7095.
I keep getting the following error report:
Setup failed for satel_integra: Integration failed to initialize.
10:00:26 AM – (ERROR) setup.py
Exception during connecting: [Errno 111] Connect call failed (‘192.168.2.150’, 7091).
10:00:26 AM – (WARNING) components/satel_integra/init.py
Anyone able to help me on this?
Thanks!
Koen
Configuration.yaml
satel_integra:
  host: 192.168.2.150
  port: 7091
  partitions:
    01:
  zones:
    01:
      name: "DC voordeur"
      type: "opening"
    02:
      name: "PIR voordeur"
etc...````
Oh yeah, I have done a nmap port scan on the ip address of the satel integra.
It seems only the ports 80, 7090 and 7091 are open…
So I suppose the integration should work on 7090 of 7091.
Still no success…
C:\Users\koen>nmap -p 1-65535 192.168.2.150
Starting Nmap 7.93 ( https://nmap.org ) at 2023-02-16 10:15 W. Europe Standard Time
Nmap scan report for 192.168.2.150
Host is up (0.0045s latency).
Not shown: 65532 closed tcp ports (reset)
PORT     STATE SERVICE
80/tcp   open  http
7090/tcp open  unknown
7091/tcp open  unknown
MAC Address: XX:XX:XX:XX:XX:XX:XX (Satel sp. z o.o.)
Nmap done: 1 IP address (1 host up) scanned in 61.04 seconds```
Hi Koen,
did You manage to fix it?
The Integration port is by default 7094 and “Integration” has to be enabled in the Panel through DLOADX or on the LCD keypad.
Ivan
Hi Ivan,
until now, I did not succeed… unfortunately,
I think that the “integration” has not been enabled…
As I can’t connect via DLOADX (still trying to contact the guy who installed the system to do it), I might try to do this via the LCD keypad…
How should I do this via the LCD keypad??
Koen
Yes!!
I was able to get into the system via KLCD.
Found out that the integration option was disabled.
I enabled the option and now I can read the sensor states.
In the end it took me several days to figure this out (as the installer of the system did not show any help :frowning: )
DLOADX still gives an error
Any idea?
Koen
what do you mean by the integration option where to enable it?
I can sometimes connect to satel from HA but it doesn’t seem to read sensor statuses.
