Satel integra with ETHM-1
Any results? :slight_smile:
Hello!
No, did not find it back than and now I only use the “Armed Away” option. :worried:
Hi, I struggle implementing everything the way it works. Integration seems to work, at least no complains. But I can´t see that the entities of my sensors from the Integra are published. Here a partial yaml code of my integration:
02:
  type: "motion"
03:
  type: "motion"
06:
  type: "motion"
switchable_outputs:
29:
30:
31:
32:
33:
34:
35:
36:
Whenever I open windows or walk through the area nothing is updated. Any ideas I could/should check?
I see you have a section switchable_outputs, are those actually switchable outputs that are being used? These would for example be heating valves, or door/gate locks that can be controlled. If you just want binary sensors, you should be able to set them in the zones property instead
Thanks for the feedback, I will change that as I guess binary sensors are the right way - I will change and try it
Hello! I was able to use my Satel Integra with ETHM-1 without needing to do anything else BUT i cant disarm the system but i can arm it, check detectors states etc. but it does stay in one state and doesn’t change. I’m really new to HA and i dont understand theese py files for ETHM 1 i don’t know where to paste them. Please help me with this
I’m working on renovating the Satel integration (adding UI config and more in the future).
I would advice to enable debug logging and try to disarm the system again. That will hopefully gather some useful logging information for somebody/me to fix it!
Thank you for your support and I’m have fingers crossed for you
