Hello all, very quick question: what’s the proper way to save and restore the energy data. I messed up my home assistant and need to start over. I can reconfigure everything easily but the only thing I really want to save is the energy consumtion data. When I hit the button download data in the energy tab, it’s downloading data corresponding to the current view only…
NB: I tried to find home-assistant_v2.db but I don’t see it in Studio Code Server, within the config folder
You can use the history tab but… I am not sure if you have thought this trhough enough. How are you going to re-import it, adding it to a new (statistic) entity? I mean …it is feasible in multiple ways but not ‘easy’ at all.
I did think about it, that’s why the question is about both the export and import
Fortunately, I’ve been able to fix my Home Assistant and don’t need to do that anymore. It would be great to have an option to export/import energy data built in Home Assistant though.
There is not much, Spook has an import service call but tbh I have not tested it against an existing entity. I myself have a integration in which I use the webservices by HA directly (which Spook also uses) but this too does not use an existing stats entity. . I have been thinking on providing a custom component for this (CRUD) but have not found the time yet (no prio)
