Save and restore state of lights
So here’s an update that stores multiple attributes for lights (and makes it easy to add others. See below.)
FWIW, the light component seems to translate all color variants (xy_color, rgb_color, color_name) into hs_color (and back again when reporting attributes.) So I figured it was best to save/restore hs_color, but of course, feel free to modify the scripts if you feel otherwise.
I’ll work on adding support for a list of entitiy_id’s to save/restore next.
Updated save_lights.py:
DOMAIN = 'light_store'
STORE_ENTITY_ID = '{}.{{}}'.format(DOMAIN)
# Select light attributes to save/restore.
ATTR_BRIGHTNESS = "brightness"
ATTR_HS_COLOR = "hs_color"
LIGHT_ATTRS = [ATTR_BRIGHTNESS, ATTR_HS_COLOR]
def store_entity_id(entity_id):
    global STORE_ENTITY_ID
    return STORE_ENTITY_ID.format(entity_id.replace('.', '_'))
# Clear out any previously saved states.
saved = hass.states.entity_ids(DOMAIN)
for entity_id in saved:
    hass.states.remove(entity_id)
all_switches = hass.states.entity_ids('switch')
all_lights = hass.states.entity_ids('light')
for entity_id in all_switches:
    cur_state = hass.states.get(entity_id)
    if cur_state is None:
        logger.error('Could not get current state for {}.'.format(entity_id))
    else:
        hass.states.set(store_entity_id(entity_id), cur_state.state)
for entity_id in all_lights:
    else:
        attributes = {}
        for attr in LIGHT_ATTRS:
            value = cur_state.attributes.get(attr)
            if value is not None:
                attributes[attr] = value
        hass.states.set(store_entity_id(entity_id), cur_state.state, attributes)
Updated restore_lights.py:
# Retrieve saved states.
    old_state = hass.states.get(store_entity_id(entity_id))
    if old_state is None:
        logger.error('No saved state for {}.'.format(entity_id))
    else:
        turn_on = old_state.state == 'on'
        service_data = {'entity_id': entity_id}
        hass.services.call('switch', 'turn_on' if turn_on else 'turn_off',
                           service_data)
    else:
        if turn_on:
                value = old_state.attributes.get(attr)
                    service_data[attr] = value
        hass.services.call('light', 'turn_on' if turn_on else 'turn_off',
                           service_data)
# Remove saved states now that we're done with them.
Ok, it took longer than expected. When they say, “The scripts are run in a sandboxed environment,” they’re not kidding!
In any case, you can now pass the following data to the scripts, both of which are optional:
store_name - Domain name used for switch/light store. Defaults to "light_store".
entity_id  - Entity IDs of switches and/or lights to save/restore.
             Defaults to all existing switches and lights.
Note that entity_id can be a single item, a list of items, or a comma separated string. E.g.:
"entity_id": "light.bulb1"
"entity_id": ["switch.switch1", "light.bulb1"]
"entity_id": "switch.switch1, light.bulb1"
# Select light attributes to save.
def store_entity_id(store_name, entity_id):
    return '{}.{}'.format(store_name, entity_id.replace('.', '_'))
# Get optional store name (default to DOMAIN.)
store_name = data.get('store_name', DOMAIN)
# Get optional list (or comma separated string) of switches & lights to
# save. If not provided, default to all.
entity_id = data.get('entity_id')
if isinstance(entity_id, str):
    entity_id = [e.strip() for e in entity_id.split(',')]
# Get lists of switches and lights to save that actually exist.
if entity_id:
    switches = tuple(set(entity_id).intersection(set(switches)))
    lights   = tuple(set(entity_id).intersection(set(lights)))
saved = hass.states.entity_ids(store_name)
for entity_id in switches:
    else:
        hass.states.set(store_entity_id(store_name, entity_id), cur_state.state)
for entity_id in lights:
    else:
        attributes = {}
        hass.states.set(store_entity_id(store_name, entity_id), cur_state.state,
                        attributes)
# Select light attributes to restore.
# restore. If not provided, default to all.
# Get lists of switches and lights to restore that actually exist.
if entity_id:
    old_state = hass.states.get(store_entity_id(store_name, entity_id))
    else:
                           service_data)
    else:
        if turn_on:
                           service_data)
Hope you find this useful!
Just wanted to say that this python script is working great so far. I used to accomplish something similar but it took a whole bunch of scripts, binary sensors etc.
FWIW, I’m thinking of combining them into just one script with an additional ‘save’ vs ‘restore’ param since there is so much overlap between them. Also, I think it would be good to change the default behavior of the restore operation when there is no list of entity_id’s. I.e., in that case, instead of trying to restore everything, just restore the same entities that were saved. This would make using the script easier - i.e., you’d only have to list the entities once (for saving, unless, of course, for some reason, you want to restore only a subset of the ones that were saved, which would still be possible by specifying that subset for the restore operation.) Thoughts?
I went ahead and made the changes I was talking about. Here is now the one script that does both (python_scripts/light_store.py):
ATTR_OPERATION  = 'operation'
ATTR_OP_SAVE    = 'save'
ATTR_OP_RESTORE = 'restore'
ATTR_STORE_NAME = 'store_name'
ATTR_ENTITY_ID  = 'entity_id'
# Get operation (default to save.)
operation = data.get(ATTR_OPERATION, ATTR_OP_SAVE)
if operation not in [ATTR_OP_SAVE, ATTR_OP_RESTORE]:
    logger.error('Invalid operation. Expected {} or {}, got: {}'.format(
        ATTR_OP_SAVE, ATTR_OP_RESTORE, operation))
else:
    store_name = data.get(ATTR_STORE_NAME, DOMAIN)
    # save/restore.
    entity_id = data.get(ATTR_ENTITY_ID)
    # Get lists of switches and lights that actually exist,
    # and list of entities that were previously saved.
    entity_ids = (hass.states.entity_ids('switch') +
                  hass.states.entity_ids('light'))
    # When restoring, limit to existing entities that were saved.
    if operation == ATTR_OP_RESTORE:
        saved_entity_ids = []
        for e in entity_ids:
            if store_entity_id(store_name, e) in saved:
                saved_entity_ids.append(e)
        entity_ids = saved_entity_ids
    # If a list of entities was specified, further limit to just those.
    # Otherwise, save all existing switches and lights, or restore
    # all existing switches and lights that were previously saved.
    if entity_id:
        entity_ids = tuple(set(entity_ids).intersection(set(entity_id)))
    if operation == ATTR_OP_SAVE:
        # Save selected switches and lights to store.
        for entity_id in entity_ids:
                logger.error('Could not get state of {}.'.format(entity_id))
            else:
                attributes = {}
                if entity_id.startswith('light.'):
    else:
        # Restore selected switches and lights from store.
            else:
                component = entity_id.split('.')[0]
                if component == 'light' and turn_on:
                hass.services.call(component,
                                   service_data)
I’ve tested it via the services page, but I haven’t yet converted over my automations & scripts to use it. I’ll do that next and update if I find any issues. Also, by all means, if you try it and find issues, please let me know.
FYI, I created the following topic where I’ll maintain my script:
I think a lot of user are missing the point of the home automation (smart house)
that we want it to happen NOW
I have heaps of smarts in my house but a reboot / restart the house is dum until everything it get in line with each other to me thats a fact of my smart house eg drive down the drive garge door open lights come on , walk out of office lights turn off.
for me house take about 2hours to when all the smarts kick in . i can live with that
door have been open/closed heater on/off getting to the stage Im only restarting when I have add a new switch/ senser.
I Like HA as it is it just does my smarts
But in saying that do hate it on my test box yes its a pain in the … but Im look ahead not in the next hour
these are just my comments about a smart house
Can you please explain how to use the save and restore option?
This is my testing package
automation:
  - id: 'light_store'
    alias: "[Licht] STORE"
      - platform: homeassistant
        event: start
      service: python_script.light_store
  - id: 'test_light_restore'
    alias: "[Test] Light Restore"
      - platform: state
        entity_id: light.arbeitszimmer_led_fenster
      - delay: 00:00:05
      - service: python_script.light_store
This will successfully store all lights statuses when (re)starting Home Assistant. However, I don’t know what to put at the bottom…
To test, I want to change the brightness for light.arbeitszimmer_led_fenster; then the automation should wait 5 seconds, and then restore the brightness to its previous value.
Did you see the doc page?
Actually I missed it and just copied the code from this thread. I’ll look into it now, thank you.
Oh, I didn’t pay close enough attention. I thought we were in this topic:
lol
For those still wanting to accomplish this without jumping through too many hoops.
You can make use of scenes to save the state beforehand and then reapply it when you want to revert back to the previous state.
- id: 'doorbell_pressed'
  alias: 'Doorbell Pressed'
  description: 'Flash lights light blue when someone presses the doorbell'
  - entity_id: binary_sensor.doorbell_button
    platform: state
    to: 'on'
  condition: []
  - data:
      scene_id: doorbell_notification_revert
      snapshot_entities: 'light.living_room'
    service: scene.create
  - data:
      effect: Facebook
      entity_id: light.living_room
    service: light.turn_on
  - delay: 00:00:04
  - data:
      entity_id: scene.doorbell_notification_revert
    service: scene.turn_on
Thanks alot for this! I found that using the python script for saving the state no longer worked but this does, and without having to add a custom script!
The caveat is that the scene made by scene.create is temporary. In other words, this technique won’t work if the goal is to restore lights on startup (like what Phil’s python_script does).
From the documentation:
Creating scenes on the fly
Create a new scene without having to configure it by calling the scene.create service. This scene will be discarded after reloading the configuration.
Otherwise, yes, scene.create is a very useful way to store/restore the state of not only lights but other entities as well.
EDIT
I was wrong. The python_script has no advantage on restart (see pnbruckner’s comments below). Therefore your suggestion to use scene.create is functionally equivalent (and self-contained within one script).
Um, sorry to disappoint, but no, it doesn’t. It saves the info to the State Machine, not in any persistent storage. The info in the State Machine is volatile, and will be lost on a restart. (The info that appears to be saved across restarts is actually reloaded from persistent storage which is used purposely to save/restore, potentially partial, state info for entities.)
I think the dynamic scene capability has mostly made my script obsolete, although there are some things it still doesn’t do that my script does.
Pardon my thick skull but I don’t know which one you’re referring to, scene.create or the python_script.
Are you saying that the scene created by scene.create survives a restart?
Sorry, I meant to say that my python_script does not restore on startup, or more accurately, does not save to persistent storage, so cannot be used to restore state that was saved before a restart.
So I guess that means neither survives a restart.
I see. OK, then I misunderstood and attributed more functionality to the python_script than warranted. I’ll amend my previous post.
