I do some calculation on node-red and send thsi over via mqtt to ha. Is there any possibility to store that value into a variable entility who is not saved into a database and only show as long HA not reboot or there is not such solution?
By the way I want display this value inside lovelace.
The only “variables” that exist in home assistant that have scope outside of automations/scripts/templates are entities themselves. You can of course create an entity that is not included in the recorder database or you can use a single entity that holds a bunch of variables for different purposes. But at the end of the day, you need to use an entity.
I have one question about that Git Variable pack. I am newbie in that topic. As I see this example variable.update_sensor
will update a real sensor or i could store my vlaue inside variable.update_sensor
And this will not save inside that database and only hold on ram?
is an action that is used to change the value of one of the sensor entities that you need to create either through the UI or in YAML.
When I said you have to store the value in an entity, I really meant it. There are probably hundreds of ways to do that (both natively and with custom integrations), but they will all end up with a value stored in an entity.
You can exclude an entity from your recorder database with these settings.
Probably the most flexible way to store variables natively is with the trigger-based template sensor described in this post:
Here’s one way to do it (there are several other ways):
- Create an Input Text helper.
- Exclude it from the Recorder integration.
- In your Node-Red flow, write your value to the Input Text.
