Hello
I have an ongoing issue. I have some automations turned on in UI and some turned off. If I edit an existing automation or create a new one ALL my automations automatically turn on in the UI.
How do I stop this from happening?
Thanks.
Hello
Thanks.
If you put ‘initial_state: ‘off’’ or ‘initial_state: ‘on’’ in the automation config then they will use that state when you reload your automations or restart HA.
ex:
- alias: Turn on livingroom lights when there is movement
initial_state: 'off'
platform: state
entity_id: sensor.motion_indoor_camera_living_room
to: 'on'
service: homeassistant.turn_on
entity_id:
- switch.west_livingroom_lights_switch
- switch.east_livingroom_lights_switch
This does not seem to work for me, I have tried initial_state: ‘off’
and initial_state: ‘false’
and both times all automations are switching back on when reloading or saving a new automation or editing an existing automation.
I use customize_glob in configuration.yaml
customize_glob:
"automation.*":
initial_state: on
AOk so to follow up your solution DOES indeed work if you add the initial_state: 'off'
directly to the automations.yaml
. HA doesn’t seem to honor the initial_state: 'off'
if placed in customisation.yaml
which is where I was setting the state.
This seems like a bug?
Thanks for your help.
I did not know about that feature, many thanks.
you don’t need ’ for on or off
just initial_state: on
initial_state: off
At least the docs here state that initial_state is possible setting to add. Who from HA side could verify?
I don’t use the automation generator in the web front end and yet despite using the below settings in my automations they will still trigger:
initial_state: off
I’ve also tried ‘false’ etc and that doesn’t work.
I’m using include dir statements to split up my config.
try wrapping off in quotes:
Nope, tried that.
I’ve tried all variations I can think of:
false
‘fase’
off
‘off’
‘disabled’
disabled
I do think it’s some kind of bug because it doesn’t always happen, but I can’t pin down exactly what changes when it does/doesn’t happen…
What version of HA are you running? It very well could be a bug in the newest version because of the new state storage system.
And make sure to correct mark:
And not:
`, or any other pointy mark
Def using the correct mark…
I’m running 0.83.3
