Still working on this one. I read around in the documents and mounted the folder as “media”. That probably makes more sense. I can now see the folder in the “Media” tab. I still do not know how to properly address the folder. Any hint appreciated.
When running the automation (save to fritz.nas) I get the following reply:
"Cannot write media/BirdCamStorage/IC25N080-ATMR04-0-01/BirdCam/BirdCam_20231105-205402.jpg, no access to path; allowlist_external_dirs may need to be adjusted in configuration.yaml"
The leading “/” seems to be missing. This appears to work in case the harddrive is not shut down. I seam to have an issue with not sufficient power for led and snapshot but I can take care of that seperately. This is the code in the automation in case it is useful for anyone in the future:
