I created this panel to schedule a wakeup light to turn on. Unfortunately every time I restart Home Assistant it forgets the input_boolean switch states. The input_number times and input_select selections are almost always saved.
I am using InfluxDB with the following .yaml. Does anyone have any ideas?
influxdb:
host: 127.0.0.1
port: 8086
database: homeassistant
default_measurement: state
include:
domains:
- input_boolean
- input_number
- input_select
exclude:
domains:
- automation
- camera
- media_player
- remote
- scene
- script
- sun
- time
- weather
- weblink
entities:
- sensor.dark_sky_apparent_temperature
- sensor.dark_sky_cloud_coverage
- sensor.dark_sky_cloud_coverage_1
- sensor.dark_sky_cloud_coverage_2
- sensor.dark_sky_cloud_coverage_3
- sensor.dark_sky_cloud_coverage_4
- sensor.dark_sky_cloud_coverage_5
- sensor.dark_sky_cloud_coverage_6
- sensor.dark_sky_cloud_coverage_7
- sensor.dark_sky_daily_high_apparent_temperature
- sensor.dark_sky_daily_high_apparent_temperature_1
- sensor.dark_sky_daily_high_apparent_temperature_2
- sensor.dark_sky_daily_high_apparent_temperature_3
- sensor.dark_sky_daily_high_apparent_temperature_4
- sensor.dark_sky_daily_high_apparent_temperature_5
- sensor.dark_sky_daily_high_apparent_temperature_6
- sensor.dark_sky_daily_high_apparent_temperature_7
- sensor.dark_sky_daily_low_apparent_temperature
- sensor.dark_sky_daily_low_apparent_temperature_1
- sensor.dark_sky_daily_low_apparent_temperature_2
- sensor.dark_sky_daily_low_apparent_temperature_3
- sensor.dark_sky_daily_low_apparent_temperature_4
- sensor.dark_sky_daily_low_apparent_temperature_5
- sensor.dark_sky_daily_low_apparent_temperature_6
- sensor.dark_sky_daily_low_apparent_temperature_7
- sensor.dark_sky_daily_max_precip_intensity
- sensor.dark_sky_daily_max_precip_intensity_1
- sensor.dark_sky_daily_max_precip_intensity_2
- sensor.dark_sky_daily_max_precip_intensity_3
- sensor.dark_sky_daily_max_precip_intensity_4
- sensor.dark_sky_daily_max_precip_intensity_5
- sensor.dark_sky_daily_max_precip_intensity_6
- sensor.dark_sky_daily_max_precip_intensity_7
- sensor.dark_sky_daily_summary
- sensor.dark_sky_hourly_summary
- sensor.dark_sky_humidity
- sensor.dark_sky_humidity_1
- sensor.dark_sky_humidity_2
- sensor.dark_sky_humidity_3
- sensor.dark_sky_humidity_4
- sensor.dark_sky_humidity_5
- sensor.dark_sky_humidity_6
- sensor.dark_sky_humidity_7
- sensor.dark_sky_icon
- sensor.dark_sky_icon_1
- sensor.dark_sky_icon_2
- sensor.dark_sky_icon_3
- sensor.dark_sky_icon_4
- sensor.dark_sky_icon_5
- sensor.dark_sky_icon_6
- sensor.dark_sky_icon_7
- sensor.dark_sky_minutely_summary
- sensor.dark_sky_nearest_storm_distance
- sensor.dark_sky_precip
- sensor.dark_sky_precip_1
- sensor.dark_sky_precip_2
- sensor.dark_sky_precip_3
- sensor.dark_sky_precip_4
- sensor.dark_sky_precip_5
- sensor.dark_sky_precip_6
- sensor.dark_sky_precip_7
- sensor.dark_sky_precip_accumulation
- sensor.dark_sky_precip_accumulation_1
- sensor.dark_sky_precip_accumulation_2
- sensor.dark_sky_precip_accumulation_3
- sensor.dark_sky_precip_accumulation_4
- sensor.dark_sky_precip_accumulation_5
- sensor.dark_sky_precip_accumulation_6
- sensor.dark_sky_precip_accumulation_7
- sensor.dark_sky_precip_intensity
- sensor.dark_sky_precip_intensity_1
- sensor.dark_sky_precip_intensity_2
- sensor.dark_sky_precip_intensity_3
- sensor.dark_sky_precip_intensity_4
- sensor.dark_sky_precip_intensity_5
- sensor.dark_sky_precip_intensity_6
- sensor.dark_sky_precip_intensity_7
- sensor.dark_sky_precip_probability
- sensor.dark_sky_precip_probability_1
- sensor.dark_sky_precip_probability_2
- sensor.dark_sky_precip_probability_3
- sensor.dark_sky_precip_probability_4
- sensor.dark_sky_precip_probability_5
- sensor.dark_sky_precip_probability_6
- sensor.dark_sky_precip_probability_7
- sensor.dark_sky_pressure
- sensor.dark_sky_pressure_1
- sensor.dark_sky_pressure_2
- sensor.dark_sky_pressure_3
- sensor.dark_sky_pressure_4
- sensor.dark_sky_pressure_5
- sensor.dark_sky_pressure_6
- sensor.dark_sky_pressure_7
- sensor.dark_sky_summary
- sensor.dark_sky_temperature
- sensor.dark_sky_wind_bearing
- sensor.dark_sky_wind_bearing_1
- sensor.dark_sky_wind_bearing_2
- sensor.dark_sky_wind_bearing_3
- sensor.dark_sky_wind_bearing_4
- sensor.dark_sky_wind_bearing_5
- sensor.dark_sky_wind_bearing_6
- sensor.dark_sky_wind_bearing_7
- sensor.dark_sky_wind_speed
- sensor.dark_sky_wind_speed_1
- sensor.dark_sky_wind_speed_2
- sensor.dark_sky_wind_speed_3
- sensor.dark_sky_wind_speed_4
- sensor.dark_sky_wind_speed_5
- sensor.dark_sky_wind_speed_6
- sensor.dark_sky_wind_speed_7
- sensor.load_15m
- sensor.memory_use_percent
- sensor.processor_use
- sensor.since_last_boot
- sensor.time
I am running HA and InfluxDB in separate docker containers on a laptop running Ubuntu Server 18.04.
