SCD30 "Measurement Initialization failed!"
I am trying to get an SCD30 sensor to work with ESPHome, but I’m always getting the message “Measurement Initialization failed!”. I got the sensor to work with an Arduino sketch with the same wiring.
Here’s my configuration:
esphome:
  platform: ESP32
  board: node32s
wifi:
  ssid: "My_SSID"
  password: "My_Password"
  ap:
    ssid: "Scd30 Fallback Hotspot"
    password: "GMmhyt6x9z6d"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "some_password"
ota:
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: True
  frequency: 50kHz
  - platform: scd30
    address: 0x61
    i2c_id: bus_a
    automatic_self_calibration: true
    co2:
      accuracy_decimals: 1
    temperature:
      name: "Workshop Temperature"
      accuracy_decimals: 2
    humidity:
      name: "Workshop Humidity"
    temperature_offset: 1.5 °C
    update_interval: 5s
Does anyone have an idea what I might be doing wrong?
The same thing happened to me and with this code it worked for me. It really looks the same but this one works.
with voltage at 3.3v
i2c:
  scl: GPIO17
  sda: GPIO16
  scan: True
  - platform: scd30
    co2:
    temperature:
      name: "SCD30 Temperature"
    humidity:
      name: "SCD30 Humidity"
    address: 0x61
    update_interval: 5s
Did you ever get this to work with an ESP32? I doesn’t work for me, only on the 8266.
I did, but honestly I don’t remember what I did differently than before. It seemed to just suddenly work.
Anyway, here’s my working yaml (I’m using an ESP32 NodeMCU):
esphome:
  platform: ESP32
  board: node32s
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_pw
  ap:
captive_portal:
# Enable logging
logger:
  level: VERY_VERBOSE
api:
  password: !secret esp_api_pw
ota:
  password: !secret esp_ota_pw
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: True
  frequency: 50kHz
  - platform: scd30
    address: 0x61
    i2c_id: bus_a
    co2:
    temperature:
    humidity:
    update_interval: 10s
As I remember it, it worked after I changed the log level to VERY_VERBOSE, but that doesn’t make any sense, so I must have changed something else.
Hm, ok… Thanks for the input!
same problem
I’m using ESP32 NodeMCU
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: True
  frequency: 50kHz
 - platform: scd30
    address: 0x61
    i2c_id: bus_a
    co2:
    temperature:
    humidity:
I have this error :
[I][i2c:033]: Scanning i2c bus for active devices...
[I][i2c:040]: Found i2c device at address 0x61
[W][scd30:089]: Measurement Initialization failed!
After search :
i2c:
  scan: True
- platform: scd30
And it work !!
Problem is :
Dont have solution to conserve this parameter…
Now my yaml :
i2c:
  scan: True
  - platform: scd30
    co2:
    temperature:
    humidity:
#     temperature_offset: 1.5 °C
    update_interval: 300s
For those who’d run into the same issue - as I did - IDK whether temperature_offset is supported at all, or erroneously present in the docs, but there is another way around.
SCD30 component is based on the sensor platform which provides a generic way to post-process values - Sensor Filter.
This works like a charm and my config looks like this now:
  - platform: scd30
    i2c_id: bus_a
    co2:
    temperature:
      name: "Basement Temperature"
      filters:
        - offset: -3.0
    humidity:
      name: "Basement Humidity"
    update_interval: 60s
I don’t know from which version of HA, but this issue (temperature_offset breaking SCD30) is now fixed. Putting in an offset lowers the temperature reading from the sensor.
I don’t know why it would be any better than just using the offset filter as suggested above though, so this sensor specific setting seems pretty redundant?
