Scene configuration
Hi, all.
There is a question concerning scene configuration.
When I create scene I can not change or delete the word “scene” from frontend:
I didn’ find any information by this at https://home-assistant.io/components/scene.
I suppose may be I’m doing something wrong, please point me way to do it right.
Thx.
Have you tried adding the scene to a group?
Also, looks like you’ve got the default home, where every item is added automatically (so you get generated card titles).
Yes, I have tried it. Here is content of my config file: (Sorry I didn’t find markup to yaml at forum to correctly format the configuration)
homeassistant:
#latitude:
#longitude:
#elevation:
unit_system: metric
#time_zone:
customize:
sensor.fake_sensor_0_7:
friendly_name: ‘Fake Temp’
switch.fake_sensor_0_8:
  friendly_name: 'Fake Led 1'
switch.fake_sensor_0_9:
  friendly_name: 'Fake Led 2'
scene.leds:
  friendly_name: 'Leds'
frontend:
http:
history:
logbook:
mysensors:
gateways:
- device: ‘/dev/ttyACM0’
baud_rate: 115200
debug: true
persistence: false
optimistic: false
group:
default_view:
view: yes
entities:
- group.sensorsgroup
- group.switchesgroup
cameras:
entities:
- camera.ffmpeg
view: yes
sensorsgroup:
entities:
- sensor.fake_sensor_0_7
switchesgroup:
entities:
- switch.fake_sensor_0_8
- switch.fake_sensor_0_9
ledsgroup:
view: true
entities:
- scene.leds
camera:
  • platform: ffmpeg
    input: /mnt/drive_e/output.mkv
scene:
  • name: leds
    entities:
    switch.fake_sensor_0_8: on
Anyway in this configuration it looks the same:
Use preformatted text when posting YAML, otherwise we can’t tell if you’ve got formatting issues.
It does not look like you have tried to make a group with you scene?
You have your ledsgroup set up as a view and instead of a group, you are showing only the entity “scene.leds”, so it shows as a card and the card gets the default title of the platform type.
To change this, create a group and name it whatever you like. Let’s call it “mynewgroup” for this example. Then add your “scene.leds” entity to that group.
Then go your ledsgroup and replace “- scene.leds” with “- group.mynewgroup” (or whatever you called it). And then restart; you should see the change and have a little better understanding on how groups and naming work.
Ok, now it works as I need and it’s clear to me how it’s working.
Thanks a lot for answers.
