motion
(Sami)
December 10, 2021, 1:50pm
1
I have an alexa timer automation. The script is being created but its just nothing similar to the state of the lights before the automation started. Very odd. I’m using a blueprint so I’ve c&p from “shot trace, automation config”
I’ve also set up scripts to create the scene, then just tried applying the scene, and its still all wrong.
- platform: state
entity_id: sensor.bedroom_dot_next_timer
condition:
- condition: not
conditions:
- condition: state
state: unavailable
- delay: >
{% set index = (((state_attr(timestamp_sensor, 'sorted_active') |
from_json)) | list | length) - 1 %} {{ ((state_attr(timestamp_sensor,
'sorted_active') | from_json)[index][1].remainingTime/ 1000)| round(0) }}
- condition: not
conditions:
- condition: state
state: unavailable
- condition: template
value_template: '{{ as_timestamp(states(timestamp_sensor)) - as_timestamp(now()) < 0| int}}'
- choose: null
default:
- service: scene.create
scene_id: timer_flash_snapshot_two
snapshot_entities: group.all_lights
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- repeat:
until:
- condition: state
state: unavailable
sequence:
- service: script.1639139959907
- service: light.turn_on
area_id:
- bedroom
- kitchen
- office
brightness_pct: 100
- wait_for_trigger:
- platform: state
attribute: status
to: 'OFF'
- service: scene.turn_on
transition: 1
entity_id: scene.timer_flash_snapshot_two
systex
December 10, 2021, 1:55pm
2
Are you sure you can snapshot groups like that? Have you tried snapshotting a single light from the light domain? You can always make a light group (rather than simply a “group”) so that you could use light.all_lights
rather than group.all_lights
motion
(Sami)
December 10, 2021, 2:13pm
3
Have changed that. Just listed all of the entities separately, still no luck.
variables:
timestamp_sensor: sensor.bedroom_dot_next_timer
- platform: state
condition:
- condition: not
conditions:
- condition: state
state: unavailable
- delay: >
- condition: not
conditions:
- condition: state
state: unavailable
- choose: null
default:
snapshot_entities:
- light.bedroom_light
- light.office_main_light
- light.dining_room_light
- light.kitchen_light
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- repeat:
until:
- condition: state
state: unavailable
sequence:
area_id:
- bedroom
- kitchen
- office
brightness_pct: 100
- wait_for_trigger:
- platform: state
attribute: status
to: 'OFF'
transition: 1
mode: single
alias: Timer Flash - Bedroom Dot
description: ''
systex
December 10, 2021, 2:17pm
4
motion:
- choose: null
default:
This seems wrong to me… why do you have a choose block with null, then a default sequence? Can you just delete that choose block since it seems you always want to execute the default sequence?
motion
(Sami)
December 10, 2021, 2:28pm
5
Hmmm, doesnt show in config.
This is what’s in my automations.yaml:
- id: '1639140214561'
description: ''
use_blueprint:
path: Do something when Alexa timer expires.yaml
input:
echo_device_next_timer: sensor.bedroom_dot_next_timer
target_action:
snapshot_entities:
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- repeat:
until:
- condition: state
state: unavailable
sequence:
area_id:
- bedroom
- kitchen
- office
brightness_pct: 100
- wait_for_trigger:
- platform: state
attribute: status
to: 'OFF'
transition: 1
And this is the contents of the blueprint I’m using:
blueprint:
name: Do something when Alexa Timer has expired
description: When a timer of an Echo or other Alexa device has expired, the defined
actions will be executed.
domain: automation
input:
description: Please select a sensor.*_next_timer entity to define the observed
Alexa Device.
selector:
entity:
domain: sensor
device_class: timestamp
target_action:
description: What should be done, when the timer expires?
selector:
action: {}
source_url: https://community.home-assistant.io/t/do-something-when-alexa-timer-has-expired/255827
variables:
timestamp_sensor: !input 'echo_device_next_timer'
- platform: state
entity_id: !input 'echo_device_next_timer'
condition:
- condition: not
conditions:
- condition: state
state: unavailable
- delay: '{% set index = (((state_attr(timestamp_sensor, ''sorted_active'') | from_json))
| list | length) - 1 %} {{ ((state_attr(timestamp_sensor, ''sorted_active'') |
- condition: not
conditions:
- condition: state
state: unavailable
< 0| int}}'
- choose:
default: !input 'target_action'
mode: parallel
max: 10
systex
December 10, 2021, 2:36pm
6
Can you try using the developer options to just call the scene.create and scene.turn_on actions and test them out? I’m thinking this may be an issue with the blueprint.
snapshot_entities:
transition: 1
motion
(Sami)
December 10, 2021, 3:14pm
7
Very odd. It worked a couple of times, and then stopped working!
motion
(Sami)
December 10, 2021, 3:30pm
8
After some testing, it seems like it works in the developer tools section, but only for lights that are currently ON. Otherwise they’re not included.
But it still doesnt work in any scripts, or automations.
systex
December 10, 2021, 4:47pm
9
This is really weird. I just tested and it works perfectly for me-- if a light is OFF when I take a snapshot, it gets turned back OFF when I turn the scene on.
motion
(Sami)
December 10, 2021, 6:54pm
10
Really weird isnt it. Do you have alexa media?
systex
December 10, 2021, 7:38pm
11
I don’t. I simply tested scene creation/application in developer tools to confirm that it captured “off” state correctly for me.
systex
December 10, 2021, 7:41pm
12
AHA! I only tested with a single light entity. However, if I use two lights, where one of them if OFF and one of them is ON, it does not capture the state of the OFF light. You can go and look at the state of the scene entity and the OFF light is simply missing.
I think it’s time to submit a bug.
Edit: and now I can’t recreate this behavior-- everything is working correctly.
As a test, can you try changing the name of the scene you’re creating and activating?
petro
(Petro)
December 10, 2021, 8:09pm
13
I use this all the time, works perfectly. Are you sure your lights have states associated with them?
motion
(Sami)
December 10, 2021, 8:52pm
14
Does this help? Sorry, I’m new!
