Still on 99.3 and wanting to update. I always use the ‘configuration checker’ in hassio.
This reports an error:
ERROR:homeassistant.scripts.check_config:BURB
File "/usr/local/lib/python3.7/site-packages/homeassistant/scripts/check_config.py", line 206, in check
async_check_ha_config_file(hass)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
return future.result()
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/check_config.py", line 140, in async_check_ha_config_file
p_validated = component_platform_schema(p_config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 205, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 285, in _exec
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/scene/__init__.py", line 45, in _platform_validator
return platform.PLATFORM_SCHEMA(config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 635, in validate_sequence
cval = validate(index_path, value)
v = func(path, v)
return schema(data)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/homeassistant/scene.py", line 38, in _convert_states
if isinstance(states[entity_id], dict):
KeyError: 'scene.gardenlight_on'
Fatal error while loading config: 'scene.gardenlight_on'
Failed config
General Errors:
- 'scene.gardenlight_on'
Successful config (partial)
I know some stuff has changed in the scene section after 101 so I checked all of that. I did not have any strange stuff in the scenes anyway and took out any transitions I had.
It seems to stall on the gardenlight scene (posted below) but also there I cannot find anything wrong. I checked all the entities and the states (eg if they would support brightness etc)
Would welcome any suggestions on what to check/change here.
- name: gardenlight_on
entities:
switch.fibaro_system_fgs221_double_relay_switch_2x15kw_switch_27_0:
state: on
switch.lamp_zijkant_huis_258:
state: on
switch.huis_buiten_114:
state: on
light.qubino_zmnhda2_flush_dimmer_level:
state: on
brightness: 52
switch.achtertuin_220:
state: on
