NielsS
November 7, 2019, 4:38pm
1
After an update I noticed that ‘transitions’ in Scenes are not working anymore.
I have entries in the scenes.yaml file like:
- name: Livingroom normal fade in
entities:
light.woonkamer:
state: on
transition: 30
brightness: 144
color_temp: 360
The lights are Ikea Tradfri.
It worked well before version 0.100
Is the syntax changed or is there a bug?
The logs do not show an error like I had with cover positions.
Transitions have been removed from scenes, as have stateless changes. Scenes are basically pointless now. Convert it to a script.
NielsS
November 8, 2019, 1:27pm
3
I tried to change it to a script but get an error: extra keys are not allowed.
Script:
Call Service
light.turn_on
light.woonkamer:
brightness: 144
color_temp: 360
state: 'on'
transition: 30
Also tried without state ‘on’ and got the same message.
If I remove the light.woonkamer, all the lights turn on
Yeah, you have to use the script syntax as you would with any other script
script:
scene_whatever:
sequence:
- service: light.turn_on
entity_id: light.woonkamer
brightness: 144
color_temp: 360
transition: 30
NielsS
November 8, 2019, 3:11pm
5
That made it work as it needed to be.
So in short: Use scripts instead of scenes for most of the scene like settings.
Am I right?
Shiro
(Shiro)
November 10, 2019, 10:54pm
7
For some reason it seems to work if all you do is change the color of a hue bulb (only tested on hue, don’t have anything else to test it on) but turning it off or on seems to ignore the transition. Makes me sad.
