I built some scenes using the editor but I’m finding that when I execute the scenes the brightness of the light stays at 100% even though the brightness slider is at 5% (the value in the scene). The values are al correct in the generated YAML.
There seems to be a disconnect between the slider (and the value set in the scene) and what actually happens when the scene is set.
Not sure how to narrow down whether this is an HA issue or an issue with MQTT or Tasmota. Any suggestions?
As I said, I don’t believe this is a YAML issue as the value is correct and the slider in the GUI does drop to the correct value even though the value in the light is not correct.
I am seeing this happen with all of my tasmota lights though it doesn’t seem to happen with my Hue lights so I assume there’s some sort of race condition taking place. I can’t be the first person that this has happened to, can I?
Awwww crap…that scene isn’t a good example an it’s not a Tasmota light though it is a Tradfri light (controlled by my Hue hub) and does exhibit the problem.
Again, this has the same issue. When the scene is set the GUI shows that the light is at full brightness but if you move the slider up and down again you can actually turn the brightness to full (the gui was showing full but the light itself is actually less than 100%)
