Scene only apply to lights not already turned on
I use scenes to control my lights according to how bright it is outside.
However its annoying when for whatever reason I’ve turned a light on to say full brightness… then as it gets dark outside my lights brightness is adjusted according to the scenes I have.
It would be nice to have a flag that essentially says only apply the scene to the lights that are turned off.
Or bonus points, only apply the brightness setting to a light if the light currently has its brightness setting lower than what is set in the scene
Cheers
Anything is possible if you use an automation :slight_smile:
