Sylvain
(Sylvain)
March 3, 2020, 2:08pm
1
Hi All,
Apologies for the possibly convoluted title, I’m struggling with this issue.
I have a number of scenes for the bedroom of my daughters that I want to display in an intuitive way when they select a button it should light up, when they select another one, that one should light up.
This is what I want it look like when I would hit the 2nd button:
poudenes
(Poudenes)
March 3, 2020, 2:38pm
2
You can do something with picture-entity:
cards:
- cards:
- entity: switch.scene1
icon_height: 10px
show_state: false
state_image:
off: /local/images/nest/gray.png
on: /local/images/nest/green.png
type: picture-entity
type: horizontal-stack
type: vertical-stack
Sylvain
(Sylvain)
March 3, 2020, 3:15pm
3
Thanks @poudenes ,
That is how I made the screenshots; my issue is that I want to change the appearance of not only the card I toggle (from off to on) but also the other cards in the horizontal stack (from on to off).
FYI, this is the code I have now
cards:
- aspect_ratio: 99%
entity: scene.brgdawn
image: local/Dawn.jpg
show_name: false
show_state: false
tap_action:
action: call-service
service: scene.turn_on
service_data:
entity_id: scene.brgdawn
- aspect_ratio: 99%
entity: scene.brgnoon
image: local/Noon.jpg
show_name: false
show_state: false
tap_action:
service_data:
entity_id: scene.brgnoon
- aspect_ratio: 99%
entity: scene.brgdusk
image: local/Dusk.jpg
show_name: false
show_state: false
tap_action:
service_data:
entity_id: scene.brgdusk
- aspect_ratio: 99%
entity: scene.brgnight
image: local/Night.jpg
show_name: false
show_state: false
tap_action:
service_data:
entity_id: scene.brgnight
poudenes
(Poudenes)
March 3, 2020, 6:01pm
4
Maybe something with a IF ELSE coding?
Sylvain
(Sylvain)
March 3, 2020, 7:35pm
5
That could work, I think, but I have no clue how to do it here… You?
The best solution I came up with is to make a set of virtual switches and toggle these from the scene, but that feels way to complicated…
AhmadK
(akasma74)
March 3, 2020, 9:12pm
6
an idea:
when you turn on a scene its state becomes on (I presume) and you can test every scene’s state, right?
then you can change appearance of your images depending on the states of scenes they represent.
for example, if you use button-card, you can apply a filter so the image will be brighter/less bright etc.
does it makes sense?
not sure you can do that using standard cards (maybe several conditional cards, I’m not familiar with picture-elements at all).
Sylvain
(Sylvain)
March 4, 2020, 8:09am
7
Hi All,
I think I solved it for about 80% (and my solution wasn’t that convoluted )
I made four dummy switches, one for each scene:
switch:
- platform: mqtt
state_topic: "DummyScene/BRGDawn/Status"
command_topic: "DummyScene/BRGDawn/Status"
payload_on: "On"
payload_off: "Off"
qos: 2
retain: true
optimistic: false
- platform: mqtt
state_topic: "DummyScene/BRGNoon/Status"
command_topic: "DummyScene/BRGNoon/Status"
payload_on: "On"
payload_off: "Off"
qos: 2
retain: true
optimistic: false
- platform: mqtt
state_topic: "DummyScene/BRGDusk/Status"
command_topic: "DummyScene/BRGDusk/Status"
payload_on: "On"
payload_off: "Off"
qos: 2
retain: true
optimistic: false
- platform: mqtt
state_topic: "DummyScene/BRGNight/Status"
command_topic: "DummyScene/BRGNight/Status"
payload_on: "On"
payload_off: "Off"
qos: 2
retain: true
optimistic: false
Updated the scene descriptions to switch the dummies as required:
# Scenes
scene:
- name: BRGDawn
alexa_description: "Girls Dawn"
alexa_display_categories: "SCENE"
alexa_hidden: false
entities:
light.bedroom_meisjes_beneden:
state: on
brightness: 100
light.bedroom_meisjes_beneden_rgbw:
state: on
brightness: 150
rgb_color: [219,144,125]
white_value: 150
switch.dummyscenebrgdawn:
state: On
switch.dummyscenebrgnoon:
state: Off
switch.dummyscenebrgdusk:
state: Off
switch.dummyscenebrgnight:
state: Off
- name: BRGNoon
alexa_description: "Girls Noon"
alexa_hidden: false
entities:
state: on
brightness: 200
state: on
brightness: 200
rgb_color: [175,175,0]
white_value: 250
state: Off
state: On
state: Off
state: Off
- name: BRGDusk
alexa_description: "Girls Dusk"
alexa_hidden: false
entities:
state: on
brightness: 75
state: on
brightness: 100
rgb_color: [206,117,194]
white_value: 150
state: Off
state: Off
state: On
state: Off
- name: BRGNight
alexa_description: "Girls Night"
alexa_hidden: false
entities:
state: off
state: off
state: Off
state: Off
state: Off
state: On
And finally changed the entity to the dummy switch in LoveLace
cards:
- aspect_ratio: 99%
entity: switch.dummyscenebrgdawn
show_name: false
show_state: false
tap_action:
service_data:
- aspect_ratio: 99%
entity: switch.dummyscenebrgnoon
show_name: false
show_state: false
tap_action:
service_data:
- aspect_ratio: 99%
entity: switch.dummyscenebrgdusk
show_name: false
show_state: false
tap_action:
service_data:
- aspect_ratio: 99%
entity: switch.dummyscenebrgnight
show_name: false
show_state: false
tap_action:
service_data:
Now only the active scene is highlighted
Hope this helps some other people as well
AhmadK
(akasma74)
March 4, 2020, 12:34pm
8
have you tried using scenes’ states instead of dummy switches?
AhmadK
(akasma74)
March 14, 2020, 6:33pm
10
a few posts up I described my untested idea
Sylvain
(Sylvain)
March 14, 2020, 6:53pm
11
Ah, what I understand is that the scene doesn’t store its state. Hence me cheating with dummy switch
AhmadK
(akasma74)
March 14, 2020, 6:56pm
12
I’m not using scenes but hoped that they are ordinary state objects and therefore are represented in state machine. Well… maybe not yet, that would be nice.
