alias: >-
Increase ventilation mode when high CO2 or Humidity detected - With scenes
(Duplicate - doesn't work)
description: Triggers max mode for N minutes, then return back
- type: value
platform: device
device_id: eca8624df19c2feb8152557453625823
entity_id: sensor.mh_z19_co2_value_2
domain: sensor
above: 1000
condition:
- condition: state
entity_id: group.tenants
state: home
- data:
scene_id: ventilation_mode_revert
snapshot_entities:
- input_select.ventilation_mode
service: scene.create
- service: input_select.select_option
option: max
entity_id: input_select.ventilation_mode
- delay:
hours: 0
minutes: 0
seconds: 40
milliseconds: 0
- data:
entity_id: scene.ventilation_mode_revert
service: scene.turn_on
mode: single
but for some reason, it doesn’t reset it to the original ventilation_mode afterwards, but puts in “low” . Here is the logbook where you can see it somehow messes that up:
I’m not sure why it behaves that way but you simply want to store/restore the state of input_select.ventilation_mode then it doesn’t require the use of a scene and can be done with a variable.
alias: Increase ventilation mode when high CO2 or Humidity detected
- platform: numeric_state
above: 1000
condition:
- condition: state
state: home
- variables:
vm: "{{ states('input_select.ventilation_mode') }}"
option: 'max'
- delay: '00:00:40'
option: '{{ vm }}'
mode: single
Thank you, I didn’t know that, it works. Nevertheless, I still believe there’s something fishy going on with the scenes and would say it’s a bug.
Glad to hear it works and provides a workaround for the issue with snapshot scenes.
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions. For more information refer to guideline 21 in the FAQ.
I actually marked that and then unmarked because it’s not solving the original problem, it’s rather a workaround… But I am gonna mark it us such for the simplicity
Yes, it’s an alternative means of achieving your goal to restore the climate entity’s state.
There doesn’t appear to be anything wrong with the way you are storing/restoring the snapshot_scene so its failure implies it has a bug. Therefore your choices are to wait for it to be corrected or use another method.
