Scene Snapshot Feature not correctly restoring RGBW bulbs
I cannot use the scene snapshot properly with my RGBW bulbs. After creating the snapshot (of the bulb at a specific kelvin, therefore using the white LED) and then restoring, it attempts to set the bulb back to white. However, the white that it sets it to uses only the RGB LEDs, when really it needs to set the W LED to a specific Kelvin level. Any suggestions?
I don’t have any bulbs like that, but it sounds like a bug. You should probably open a github issue.
Okay, thanks. I’ve opened up a GitHub issue here.
