Scene to open shutters not working, while one to close them is
Hi all,
I have 3 scenes for controlling my shutters. One to open them, one to close and one for cracking them open a smidge.
Everything was working fine until I added a new shutter a couple weeks ago (it’s the Study Window in the following script).
Both Heatwave and Closed scene work, but the Open does nothing. I even tried deleting the scene and creating it again, no success.
If I open it through the HE frontend while the shutters are open they show as open in the scene. If I open it when they are closed, they show as closed. I open them from within the scene editor, save, and… nothing. Same behavior.
I’m at my wit’s end to understand what’s happening.
I’m sure it’s something stupid, but I can’t seem to figure it out.
I’m using:
Home Assistant 2022.9.1
Supervisor 2022.08.6
Operating System 8.5
Frontend 20220907.0 - latest
Thanks a million!
- id: '1654681353643'
  entities:
    cover.0xa4c13839de6d453d:
      current_position: 0
      backlight_mode: LOW
      calibration: 'OFF'
      calibration_time: 15.3
      linkquality: 255
      motor_reversal: 'ON'
      moving: STOP
      position: 0
      friendly_name: Living Room Window
      supported_features: 15
      state: open
    cover.0xa4c138257227158b:
      current_position: 0
      backlight_mode: LOW
      calibration: 'OFF'
      calibration_time: 23.2
      linkquality: 255
      motor_reversal: 'OFF'
      moving: STOP
      position: 0
      friendly_name: Living Room Door
      state: open
    cover.0xa4c138deb016510e:
      current_position: 0
      backlight_mode: LOW
      calibration: 'OFF'
      calibration_time: 19.4
      linkquality: 255
      moving: STOP
      position: 0
      friendly_name: Kitchen Door
      state: open
    cover.0xa4c1381f55fc6698:
      current_position: 0
      backlight_mode: LOW
      calibration: 'OFF'
      calibration_time: 13.9
      linkquality: 255
      moving: STOP
      position: 0
      friendly_name: Kitchen Window
      state: open
    cover.0xa4c1388f1c418338:
      current_position: 0
      backlight_mode: LOW
      calibration: 'OFF'
      calibration_time: 24.7
      linkquality: 255
      moving: STOP
      position: 0
      friendly_name: Dining Room Bay
      state: open
    cover.0xa4c1382ba5d4b92f:
      current_position: 0
      backlight_mode: LOW
      calibration: 'OFF'
      calibration_time: 23.3
      linkquality: 255
      moving: STOP
      position: 0
      friendly_name: Dining Room Door
      state: open
    cover.study_window:
      current_position: 0
      backlight_mode: LOW
      calibration: 'OFF'
      calibration_time: 15.2
      linkquality: 255
      moving: STOP
      position: 0
      friendly_name: Study Window
      state: open
  icon: mdi:window-shutter
  metadata: {}
- id: '1657622392218'
  name: 'Shutters Heatwave '
  entities:
      current_position: 16
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 16
      state: open
      current_position: 14
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 14
      state: open
      current_position: 15
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 15
      state: open
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 14
      state: open
      current_position: 17
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 17
      state: open
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 15
      state: open
    cover.study_window:
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 14
      state: open
  icon: mdi:window-shutter-alert
  metadata: {}
- id: '1662212551096'
  entities:
      current_position: 100
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 100
      state: closed
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 100
      state: closed
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 100
      state: closed
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 100
      state: closed
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 100
      state: closed
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 100
      state: closed
    cover.study_window:
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 100
      state: closed
  icon: mdi:window-shutter-open
  metadata: {}`
Logs? Hard to say without them.
What logs do you need and where do I find them? (sorry I’m kind of new to this).
If I set the opening to 99% instead of 100% the scene activates correctly. Could it be a HA bug?
Yes, I saw that, but, as wondering which logs would be most helpful in this case? Guess I’ll upload them all then.
But seems to me like it’s an edge case bug somewhere since everything works as it should with values 0-99 but not 100.
Maybe HAS, maybe Mosquitto or Zigbee2mqtt… dunno.
I will post the logs tonight though, thanks!
Z2M - didn’t know you were using that.
I would start with the ha logs.
Edit: you might need to bump up logging Logger - Home Assistant
OK, so I set logging to debug (config YAML included just in case I did something wrong):
logger:
  default: debug
  logs:
    zigbee2mqtt: debug
What I did during the time of the logs:
  • Activate “Shutters Closed” scene (OK)
  • Activate “Shutters Open” scene (KO)
  • Edit “Shutters Open” scene and set each shutter to 100, although they should already be set to 100 (all shutters open as expected)
Zigbee2mqtt log: zigbee2mqtt - Pastebin.com
Homeassistant log when I select the “Shutters Closed” scene:
2022-09-17 21:20:08.095 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547403391776] Sending {"id":3,"type":"event","event":{"c":{"scene.shutters_closed":{"+":{"s":"2022-09-17T19:20:08.089555+00:00","lc":1663442408.089821,"c":{"user_id":"f5a6ef5b8b3f4ae281b229f3589e4f86","id":"01GD6E9MMPCKAKMT50HHZMFMDJ"}}}}}}
2022-09-17 21:20:08.098 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c13839de6d453d, position=0>
2022-09-17 21:20:08.099 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c138257227158b, position=0>
2022-09-17 21:20:08.100 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c138deb016510e, position=0>
2022-09-17 21:20:08.100 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c1381f55fc6698, position=0>
2022-09-17 21:20:08.101 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c1388f1c418338, position=0>
2022-09-17 21:20:08.102 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c1382ba5d4b92f, position=0>
2022-09-17 21:20:08.103 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c13839de6d453d, position=0>)
2022-09-17 21:20:08.104 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c138257227158b, position=0>)
2022-09-17 21:20:08.105 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c138deb016510e, position=0>)
2022-09-17 21:20:08.106 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c1381f55fc6698, position=0>)
2022-09-17 21:20:08.107 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c1388f1c418338, position=0>)
2022-09-17 21:20:08.107 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.0xa4c1382ba5d4b92f, position=0>)
2022-09-17 21:20:08.109 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.study_window, position=0>
2022-09-17 21:20:08.116 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=set_cover_position, service_data=entity_id=cover.study_window, position=0>)
2022-09-17 21:20:08.117 DEBUG (SyncWorker_1) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m208), 'b'zigbee2mqtt/Living Room Window/set'', ... (17 bytes)
2022-09-17 21:20:08.119 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Living Room Window/set: '{ "position": 0 }', mid: 208
2022-09-17 21:20:08.121 DEBUG (SyncWorker_1) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m209), 'b'zigbee2mqtt/Living Room Door/set'', ... (17 bytes)
2022-09-17 21:20:08.123 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Living Room Door/set: '{ "position": 0 }', mid: 209
2022-09-17 21:20:08.126 DEBUG (SyncWorker_7) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m210), 'b'zigbee2mqtt/Kitchen Door/set'', ... (17 bytes)
2022-09-17 21:20:08.128 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Kitchen Door/set: '{ "position": 0 }', mid: 210
2022-09-17 21:20:08.129 DEBUG (SyncWorker_5) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m211), 'b'zigbee2mqtt/Kitchen Window/set'', ... (17 bytes)
2022-09-17 21:20:08.130 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Kitchen Window/set: '{ "position": 0 }', mid: 211
2022-09-17 21:20:08.132 DEBUG (SyncWorker_6) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m212), 'b'zigbee2mqtt/Dining Room Bay/set'', ... (17 bytes)
2022-09-17 21:20:08.137 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Dining Room Bay/set: '{ "position": 0 }', mid: 212
2022-09-17 21:20:08.138 DEBUG (SyncWorker_4) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m213), 'b'zigbee2mqtt/Dining Room Door/set'', ... (17 bytes)
2022-09-17 21:20:08.141 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Dining Room Door/set: '{ "position": 0 }', mid: 213
2022-09-17 21:20:08.144 DEBUG (SyncWorker_7) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m214), 'b'zigbee2mqtt/Study Window/set'', ... (17 bytes)
2022-09-17 21:20:08.147 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Study Window/set: '{ "position": 0 }', mid: 214
2022-09-17 21:20:08.150 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547403391776] Sending {"id":53,"type":"result","success":true,"result":{"context":{"id":"01GD6E9MMPCKAKMT50HHZMFMDJ","parent_id":null,"user_id":"f5a6ef5b8b3f4ae281b229f3589e4f86"}}}
2022-09-17 21:20:08.283 DEBUG (Thread-2 (_thread_main)) [paho.mqtt.client] Received PUBLISH (d0, q0, r0, m0), 'zigbee2mqtt/Living Room Window', ...  (153 bytes)
2022-09-17 21:20:08.284 DEBUG (MainThread) [homeassistant.components.mqtt.client] Received message on zigbee2mqtt/Living Room Window: b'{"backlight_mode":"LOW","calibration":"OFF","calibration_time":15.3,"linkquality":255,"motor_reversal":"ON","moving":"STOP","position":0,"state":"CLOSE"}'
2022-09-17 21:20:08.285 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=cover.0xa4c13839de6d453d, old_state=<state cover.0xa4c13839de6d453d=closed; current_position=100, backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=100, friendly_name=Living Room Window, supported_features=15 @ 2022-09-17T21:19:11.936223+02:00>, new_state=<state cover.0xa4c13839de6d453d=closed; current_position=100, backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, friendly_name=Living Room Window, supported_features=15 @ 2022-09-17T21:19:11.936223+02:00>>
2022-09-17 21:20:08.286 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.0xa4c13839de6d453d_calibration, old_state=<state switch.0xa4c13839de6d453d_calibration=off; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=100, icon=mdi:progress-wrench, friendly_name=Living Room Window calibration @ 2022-09-17T21:17:45.561651+02:00>, new_state=<state switch.0xa4c13839de6d453d_calibration=off; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, icon=mdi:progress-wrench, friendly_name=Living Room Window calibration @ 2022-09-17T21:17:45.561651+02:00>>
2022-09-17 21:20:08.287 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.0xa4c13839de6d453d_motor_reversal, old_state=<state switch.0xa4c13839de6d453d_motor_reversal=on; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=100, icon=mdi:arrow-left-right, friendly_name=Living Room Window motor_reversal @ 2022-09-17T21:17:45.576114+02:00>, new_state=<state switch.0xa4c13839de6d453d_motor_reversal=on; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, icon=mdi:arrow-left-right, friendly_name=Living Room Window motor_reversal @ 2022-09-17T21:17:45.576114+02:00>>
2022-09-17 21:20:08.289 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.0xa4c13839de6d453d_moving, old_state=<state sensor.0xa4c13839de6d453d_moving=STOP; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=100, friendly_name=Living Room Window moving @ 2022-09-17T21:19:27.842646+02:00>, new_state=<state sensor.0xa4c13839de6d453d_moving=STOP; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, friendly_name=Living Room Window moving @ 2022-09-17T21:19:27.842646+02:00>>
2022-09-17 21:20:08.291 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=cover.0xa4c13839de6d453d, old_state=<state cover.0xa4c13839de6d453d=closed; current_position=100, backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=100, friendly_name=Living Room Window, supported_features=15 @ 2022-09-17T21:19:11.936223+02:00>, new_state=<state cover.0xa4c13839de6d453d=closed; current_position=100, backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, friendly_name=Living Room Window, supported_features=15 @ 2022-09-17T21:19:11.936223+02:00>>)
2022-09-17 21:20:08.292 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=switch.0xa4c13839de6d453d_calibration, old_state=<state switch.0xa4c13839de6d453d_calibration=off; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=100, icon=mdi:progress-wrench, friendly_name=Living Room Window calibration @ 2022-09-17T21:17:45.561651+02:00>, new_state=<state switch.0xa4c13839de6d453d_calibration=off; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, icon=mdi:progress-wrench, friendly_name=Living Room Window calibration @ 2022-09-17T21:17:45.561651+02:00>>)
2022-09-17 21:20:08.293 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=switch.0xa4c13839de6d453d_motor_reversal, old_state=<state switch.0xa4c13839de6d453d_motor_reversal=on; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=100, icon=mdi:arrow-left-right, friendly_name=Living Room Window motor_reversal @ 2022-09-17T21:17:45.576114+02:00>, new_state=<state switch.0xa4c13839de6d453d_motor_reversal=on; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, icon=mdi:arrow-left-right, friendly_name=Living Room Window motor_reversal @ 2022-09-17T21:17:45.576114+02:00>>)
2022-09-17 21:20:08.294 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=sensor.0xa4c13839de6d453d_moving, old_state=<state sensor.0xa4c13839de6d453d_moving=STOP; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=100, friendly_name=Living Room Window moving @ 2022-09-17T21:19:27.842646+02:00>, new_state=<state sensor.0xa4c13839de6d453d_moving=STOP; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, friendly_name=Living Room Window moving @ 2022-09-17T21:19:27.842646+02:00>>)
2022-09-17 21:20:08.296 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.0xa4c13839de6d453d_calibration_time, old_state=<state sensor.0xa4c13839de6d453d_calibration_time=15.3; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=100, unit_of_measurement=S, icon=mdi:wrench-clock, friendly_name=Living Room Window calibration time @ 2022-09-17T21:17:45.579142+02:00>, new_state=<state sensor.0xa4c13839de6d453d_calibration_time=15.3; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, unit_of_measurement=S, icon=mdi:wrench-clock, friendly_name=Living Room Window calibration time @ 2022-09-17T21:17:45.579142+02:00>>
2022-09-17 21:20:08.298 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=select.0xa4c13839de6d453d_backlight_mode, old_state=<state select.0xa4c13839de6d453d_backlight_mode=LOW; options=['LOW', 'MEDIUM', 'HIGH'], backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=100, icon=mdi:lightbulb, friendly_name=Living Room Window backlight mode @ 2022-09-17T21:17:45.581880+02:00>, new_state=<state select.0xa4c13839de6d453d_backlight_mode=LOW; options=['LOW', 'MEDIUM', 'HIGH'], backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, icon=mdi:lightbulb, friendly_name=Living Room Window backlight mode @ 2022-09-17T21:17:45.581880+02:00>>
2022-09-17 21:20:08.299 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=cover.0xa4c13839de6d453d, old_state=<state cover.0xa4c13839de6d453d=closed; current_position=100, backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, friendly_name=Living Room Window, supported_features=15 @ 2022-09-17T21:19:11.936223+02:00>, new_state=<state cover.0xa4c13839de6d453d=closed; current_position=0, backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, friendly_name=Living Room Window, supported_features=15 @ 2022-09-17T21:19:11.936223+02:00>>
Homeassistant log when I select the “Shutters Open” scene:
2022-09-17 21:20:30.325 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547403391776] Received {'type': 'call_service', 'domain': 'scene', 'service': 'turn_on', 'service_data': {'entity_id': 'scene.shutters_open'}, 'id': 54}
2022-09-17 21:20:30.327 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=scene, service=turn_on, service_data=entity_id=scene.shutters_open>
2022-09-17 21:20:30.330 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=scene.shutters_open, old_state=<state scene.shutters_open=2022-09-17T19:20:06.396766+00:00; entity_id=['cover.0xa4c13839de6d453d', 'cover.0xa4c138257227158b', 'cover.0xa4c138deb016510e', 'cover.0xa4c1381f55fc6698', 'cover.0xa4c1388f1c418338', 'cover.0xa4c1382ba5d4b92f', 'cover.study_window'], id=1662212551096, icon=mdi:window-shutter-open, friendly_name=Shutters Open @ 2022-09-17T21:20:06.397017+02:00>, new_state=<state scene.shutters_open=2022-09-17T19:20:30.329778+00:00; entity_id=['cover.0xa4c13839de6d453d', 'cover.0xa4c138257227158b', 'cover.0xa4c138deb016510e', 'cover.0xa4c1381f55fc6698', 'cover.0xa4c1388f1c418338', 'cover.0xa4c1382ba5d4b92f', 'cover.study_window'], id=1662212551096, icon=mdi:window-shutter-open, friendly_name=Shutters Open @ 2022-09-17T21:20:30.330059+02:00>>
2022-09-17 21:20:30.331 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547787541616] Sending {"id":2,"type":"event","event":{"c":{"scene.shutters_open":{"+":{"s":"2022-09-17T19:20:30.329778+00:00","lc":1663442430.330059,"c":"01GD6EAABQKGTXG5EZBJDVYQ3A"}}}}}
2022-09-17 21:20:30.332 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=scene, service=turn_on, service_data=entity_id=scene.shutters_open>)
2022-09-17 21:20:30.333 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=scene.shutters_open, old_state=<state scene.shutters_open=2022-09-17T19:20:06.396766+00:00; entity_id=['cover.0xa4c13839de6d453d', 'cover.0xa4c138257227158b', 'cover.0xa4c138deb016510e', 'cover.0xa4c1381f55fc6698', 'cover.0xa4c1388f1c418338', 'cover.0xa4c1382ba5d4b92f', 'cover.study_window'], id=1662212551096, icon=mdi:window-shutter-open, friendly_name=Shutters Open @ 2022-09-17T21:20:06.397017+02:00>, new_state=<state scene.shutters_open=2022-09-17T19:20:30.329778+00:00; entity_id=['cover.0xa4c13839de6d453d', 'cover.0xa4c138257227158b', 'cover.0xa4c138deb016510e', 'cover.0xa4c1381f55fc6698', 'cover.0xa4c1388f1c418338', 'cover.0xa4c1382ba5d4b92f', 'cover.study_window'], id=1662212551096, icon=mdi:window-shutter-open, friendly_name=Shutters Open @ 2022-09-17T21:20:30.330059+02:00>>)
2022-09-17 21:20:30.339 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547403391776] Sending {"id":3,"type":"event","event":{"c":{"scene.shutters_open":{"+":{"s":"2022-09-17T19:20:30.329778+00:00","lc":1663442430.330059,"c":"01GD6EAABQKGTXG5EZBJDVYQ3A"}}}}}
2022-09-17 21:20:30.342 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c13839de6d453d>
2022-09-17 21:20:30.343 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c138257227158b>
2022-09-17 21:20:30.344 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c138deb016510e>
2022-09-17 21:20:30.344 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c1381f55fc6698>
2022-09-17 21:20:30.345 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c1388f1c418338>
2022-09-17 21:20:30.346 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c1382ba5d4b92f>
2022-09-17 21:20:30.347 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: CommitTask()
2022-09-17 21:20:30.350 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f8c48ee40> checked out from pool
2022-09-17 21:20:30.347 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.study_window>
2022-09-17 21:20:30.355 DEBUG (SyncWorker_3) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m215), 'b'zigbee2mqtt/Living Room Window/set'', ... (5 bytes)
2022-09-17 21:20:30.361 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Living Room Window/set: 'CLOSE', mid: 215
2022-09-17 21:20:30.363 DEBUG (SyncWorker_1) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m216), 'b'zigbee2mqtt/Living Room Door/set'', ... (5 bytes)
2022-09-17 21:20:30.379 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Living Room Door/set: 'CLOSE', mid: 216
2022-09-17 21:20:30.381 DEBUG (SyncWorker_0) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m217), 'b'zigbee2mqtt/Kitchen Door/set'', ... (5 bytes)
2022-09-17 21:20:30.389 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Kitchen Door/set: 'CLOSE', mid: 217
2022-09-17 21:20:30.392 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f8c48ee40> being returned to pool
2022-09-17 21:20:30.392 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f8c48ee40> rollback-on-return
2022-09-17 21:20:30.393 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c13839de6d453d>)
2022-09-17 21:20:30.394 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c138257227158b>)
2022-09-17 21:20:30.394 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c138deb016510e>)
2022-09-17 21:20:30.395 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c1381f55fc6698>)
2022-09-17 21:20:30.396 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c1388f1c418338>)
2022-09-17 21:20:30.396 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.0xa4c1382ba5d4b92f>)
2022-09-17 21:20:30.397 DEBUG (SyncWorker_5) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m218), 'b'zigbee2mqtt/Kitchen Window/set'', ... (5 bytes)
2022-09-17 21:20:30.397 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=cover, service=close_cover, service_data=entity_id=cover.study_window>)
2022-09-17 21:20:30.402 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Kitchen Window/set: 'CLOSE', mid: 218
2022-09-17 21:20:30.404 DEBUG (SyncWorker_6) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m219), 'b'zigbee2mqtt/Dining Room Bay/set'', ... (5 bytes)
2022-09-17 21:20:30.407 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Dining Room Bay/set: 'CLOSE', mid: 219
2022-09-17 21:20:30.410 DEBUG (SyncWorker_4) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m220), 'b'zigbee2mqtt/Dining Room Door/set'', ... (5 bytes)
2022-09-17 21:20:30.420 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Dining Room Door/set: 'CLOSE', mid: 220
2022-09-17 21:20:30.422 DEBUG (SyncWorker_7) [paho.mqtt.client] Sending PUBLISH (d0, q0, r0, m221), 'b'zigbee2mqtt/Study Window/set'', ... (5 bytes)
2022-09-17 21:20:30.426 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on zigbee2mqtt/Study Window/set: 'CLOSE', mid: 221
2022-09-17 21:20:30.427 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547403391776] Sending {"id":54,"type":"result","success":true,"result":{"context":{"id":"01GD6EAABQKGTXG5EZBJDVYQ3A","parent_id":null,"user_id":"f5a6ef5b8b3f4ae281b229f3589e4f86"}}}
2022-09-17 21:20:30.464 DEBUG (Thread-2 (_thread_main)) [paho.mqtt.client] Received PUBLISH (d0, q0, r0, m0), 'zigbee2mqtt/Living Room Window', ...  (152 bytes)
2022-09-17 21:20:30.467 DEBUG (MainThread) [homeassistant.components.mqtt.client] Received message on zigbee2mqtt/Living Room Window: b'{"backlight_mode":"LOW","calibration":"OFF","calibration_time":15.3,"linkquality":255,"motor_reversal":"ON","moving":"DOWN","position":0,"state":"OPEN"}'
2022-09-17 21:20:30.469 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=cover.0xa4c13839de6d453d, old_state=<state cover.0xa4c13839de6d453d=open; current_position=0, backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, friendly_name=Living Room Window, supported_features=15 @ 2022-09-17T21:20:08.330517+02:00>, new_state=<state cover.0xa4c13839de6d453d=open; current_position=0, backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, friendly_name=Living Room Window, supported_features=15 @ 2022-09-17T21:20:08.330517+02:00>>
2022-09-17 21:20:30.470 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.0xa4c13839de6d453d_calibration, old_state=<state switch.0xa4c13839de6d453d_calibration=off; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, icon=mdi:progress-wrench, friendly_name=Living Room Window calibration @ 2022-09-17T21:17:45.561651+02:00>, new_state=<state switch.0xa4c13839de6d453d_calibration=off; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, icon=mdi:progress-wrench, friendly_name=Living Room Window calibration @ 2022-09-17T21:17:45.561651+02:00>>
2022-09-17 21:20:30.471 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.0xa4c13839de6d453d_motor_reversal, old_state=<state switch.0xa4c13839de6d453d_motor_reversal=on; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, icon=mdi:arrow-left-right, friendly_name=Living Room Window motor_reversal @ 2022-09-17T21:17:45.576114+02:00>, new_state=<state switch.0xa4c13839de6d453d_motor_reversal=on; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, icon=mdi:arrow-left-right, friendly_name=Living Room Window motor_reversal @ 2022-09-17T21:17:45.576114+02:00>>
2022-09-17 21:20:30.472 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.0xa4c13839de6d453d_moving, old_state=<state sensor.0xa4c13839de6d453d_moving=STOP; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, friendly_name=Living Room Window moving @ 2022-09-17T21:20:23.791649+02:00>, new_state=<state sensor.0xa4c13839de6d453d_moving=STOP; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, friendly_name=Living Room Window moving @ 2022-09-17T21:20:23.791649+02:00>>
2022-09-17 21:20:30.473 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=cover.0xa4c13839de6d453d, old_state=<state cover.0xa4c13839de6d453d=open; current_position=0, backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, friendly_name=Living Room Window, supported_features=15 @ 2022-09-17T21:20:08.330517+02:00>, new_state=<state cover.0xa4c13839de6d453d=open; current_position=0, backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, friendly_name=Living Room Window, supported_features=15 @ 2022-09-17T21:20:08.330517+02:00>>)
2022-09-17 21:20:30.475 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=switch.0xa4c13839de6d453d_calibration, old_state=<state switch.0xa4c13839de6d453d_calibration=off; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, icon=mdi:progress-wrench, friendly_name=Living Room Window calibration @ 2022-09-17T21:17:45.561651+02:00>, new_state=<state switch.0xa4c13839de6d453d_calibration=off; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, icon=mdi:progress-wrench, friendly_name=Living Room Window calibration @ 2022-09-17T21:17:45.561651+02:00>>)
2022-09-17 21:20:30.476 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=switch.0xa4c13839de6d453d_motor_reversal, old_state=<state switch.0xa4c13839de6d453d_motor_reversal=on; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, icon=mdi:arrow-left-right, friendly_name=Living Room Window motor_reversal @ 2022-09-17T21:17:45.576114+02:00>, new_state=<state switch.0xa4c13839de6d453d_motor_reversal=on; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, icon=mdi:arrow-left-right, friendly_name=Living Room Window motor_reversal @ 2022-09-17T21:17:45.576114+02:00>>)
2022-09-17 21:20:30.472 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.0xa4c13839de6d453d_calibration_time, old_state=<state sensor.0xa4c13839de6d453d_calibration_time=15.3; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, unit_of_measurement=S, icon=mdi:wrench-clock, friendly_name=Living Room Window calibration time @ 2022-09-17T21:17:45.579142+02:00>, new_state=<state sensor.0xa4c13839de6d453d_calibration_time=15.3; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, unit_of_measurement=S, icon=mdi:wrench-clock, friendly_name=Living Room Window calibration time @ 2022-09-17T21:17:45.579142+02:00>>
2022-09-17 21:20:30.480 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=select.0xa4c13839de6d453d_backlight_mode, old_state=<state select.0xa4c13839de6d453d_backlight_mode=LOW; options=['LOW', 'MEDIUM', 'HIGH'], backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=STOP, position=0, icon=mdi:lightbulb, friendly_name=Living Room Window backlight mode @ 2022-09-17T21:17:45.581880+02:00>, new_state=<state select.0xa4c13839de6d453d_backlight_mode=LOW; options=['LOW', 'MEDIUM', 'HIGH'], backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, icon=mdi:lightbulb, friendly_name=Living Room Window backlight mode @ 2022-09-17T21:17:45.581880+02:00>>
2022-09-17 21:20:30.483 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.0xa4c13839de6d453d_moving, old_state=<state sensor.0xa4c13839de6d453d_moving=STOP; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, friendly_name=Living Room Window moving @ 2022-09-17T21:20:23.791649+02:00>, new_state=<state sensor.0xa4c13839de6d453d_moving=DOWN; backlight_mode=LOW, calibration=OFF, calibration_time=15.3, linkquality=255, motor_reversal=ON, moving=DOWN, position=0, friendly_name=Living Room Window moving @ 2022-09-17T21:20:30.483142+02:00>>
Weirdly, position=0 is sent in both cases.
The entire HA log is 4.4Mb large, if you really want all of it, I could fileshare it somewhere. Just ask :slight_smile:
I forgot to include the content of the “Open Shutters” scene which does contain position=100
  entities:
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: STOP
      position: 100
      state: closed
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: UP
      position: 100
      state: closed
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: UP
      position: 100
      state: closed
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: UP
      position: 100
      state: closed
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: UP
      position: 100
      state: closed
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: UP
      position: 100
      state: closed
    cover.study_window:
      backlight_mode: LOW
      calibration: 'OFF'
      linkquality: 255
      moving: UP
      position: 100
      state: closed
  metadata: {}
And if I set it to 99, it works perfectly.
This definitely smells like a bug, but can’t seem to narrow down what is causing it.
Turns out it was a Zigbee2mqtt bug. Latest update solved the issue.
