Scene toggle: on/off - rotate different on scenes
This blueprint toggles your devices on/off using scenes. But it lets you switch between different scenes with multiple executions (e.g. button presses). It will remember the last activated scene when you turn on later.
This was inspired by Simple Scene Toggle from panhans.
Edits:
  • Add optional time restricted default scenes that will be activated first instead of the last on scene. This can be used e.g. to activate a dimm scene during night.
Ideas for feature extensions in the future:
  • eleminate the need for an off scene by automatically detecting all devices used in the on scenes
ko-fi
Source Code
This is a really great blueprint.
It effectively simulates how Philips Hue cycles through scenes and has the optional On/Off behavior after a short timeout.
Surprisingly, this is also a Time Based scene script! I was able to use this to replace the Hue time based light action and have it be almost identical to the Hue functionality.
Thank you for writing this. I know it is an adaptation of another script, but the On/Off addition is extremely important for me. So thanks!
Thank you for your feedback. This is really encouraging.
From time to time I’m still working the script. Some topics, that I have on my mind:
  • eliminate the need for the off scene by retreiving all entities from the other scenes
  • add a parameter toggle/on/off to support seperate on/off switches/buttons. On would switch between the different on scenes, off would always turn everything off, toggle would be the current behaviour.
  • improve documentation
I’m also open to suggestions for improvements or useful features.
The off behaviour for me is not working. Is that feature included in the latest version? does it detect all devices used in the scenes automatically?
Thanks for that great blueprint and its evolution!
I am wondering which processing mode of the calling automation is the prefered mode: single, restart queued, parallel?
