Scene with Z-wave light - set RGB code
I’m trying to setup scenes with my z-wave Aeon Labs RGBW led light, i.e. change the color to a specific RGB-code.
I’ve tried to use the commands from the light component ( https://home-assistant.io/components/light/ ), but no success. This is the code I tried to use and it only makes the the light turn on. I’ve also tried using profiles and effects but no luck…
  - name: Test1
    entities:
        light.aeotec_zw098_led_bulb_level_2:
            state: on
            brightness: 100
            color_temp: 100
            rgb_color: [255,100,100]
            transition: 2
Any ideas? I have not found any good documentation for z-wave lights in HA…
And a second question regarding scenes. How do I make the scene switch be a toggle switch instead of text (“Activate”)?
//Fredrik
Is this acutal??
Do you find a solution??
